Question about Singer 7466 Mechanical Sewing Machine
Singer 7466 opening plastic case?
On Singer 7466, I need to get into the case. The foot control cable was jerked hard and the female receptical for the 1/8" phone plug end of the cable was broken off. So the female receptical dropped somewhere inside the case and the sleeve and tighting ring dropped off outside.
I remove all the visable screws from the case, and it is free outside and below the bobbin case, but not free at all from the metal sewing plate back along the sewing surface, up the inside arc of the case.
It is free along the bottom and top but hanging up on the back of the case where the on/off rocker switch projects out a little and stops the case from moving to separate from the other front half of the case
  • 7 more comments
  • William Speckman Sep 05, 2008
    no way to remove rocker switch, and of course no help on the inside arc portion of the case. Please only answer if you've worked on this machine.
    Nothing there on case teardowns of any machine. The Q&A is mostly needle and bobbin handling issues, and they are in the business of selling machines and parts and doing repairs- the Q&A is just to keep people sewing, not to help them do repairs.
    This manual comes with the machine, I've thoroughly reviewed it and it has absolutely nothing about getting the case off.
    go to a repair shop is your expert answer?
    This answer had nothing addressing my question and the manual was how to sew (not how to repair) on a different, serging machine. Does anybody read the question before they answer?
    no opening large enough for the parts to fall out of, and the receptical will be connected by the electrical wires that carry the foot control's signal to the motor and thus the parts will be tethered inside the case. And sew doctor had nothing to help me.
    I have the 81 page instruction manual - nothing about case breakdowns in it. Safemanuals, diplodocs etc only have this manual. I know they promise everything, but the same manual is all they have.
    I cannot unmount the switch, it is entirely wrapped in the case and presumably only dismounts with the case off. It does not budge no matter what I do.
    Probably I don't need to worry about the switch area, it is the inside arc (between the needle and the selection panel of the plastic case that is still firmly together that keeps everything else from falling apart.
    STOP with the manual. I HAVE THE MANUAL. IT ONLY TELLS YOU HOW TO SEW. STOP SUGGESTING THE MANUAL, PROVIDE SOME EXPERITISE!!!
  • William Speckman Sep 06, 2008
    There are no screws in the bobbin case and none that I hadn't found. I finally found and forced the two loop and tongue plastic connectors I hadn't found, one on the vertical surface of the inner curve, one halfway back from the sewing plate.
    President:
  • 1,263 Answers
You can remove the rocker switch this will allow you to move the case away which inturn will allow more access
Posted on Sep 05, 2008
  • 2 more comments
  • Ronald Mueller
    Ronald Mueller Sep 05, 2008
    you say that the pieces you are trying to retrieve are lodged down in the case. have you tried to shake them out. I know that seems silly but it's worked before. it's a long shot and i have yet to find a exploded view of your machine.
  • Ronald Mueller
    this web site has schematics for your machine www.safemanuals.com this should help you disassemble the machine properly. good luck. please change the rating if you feel i have been helpful.. thank you
  • Ronald Mueller
    will the case seperat from the base at all?
  • Ronald Mueller
    there is only three things that will keep the case fastened to the base 1.. screws and there will be a couple in the bobbin compartment. 2...around the base you will find detents that you have to pry carefully with a flat tip screwdriver. 3 it was custom glued at the factory which would be damaged if you try to pry apart. incidently if it is glued at the repair shop the would just wreck the base and assemble it with a new one and they would still use glue to keep it that way. hope this helps a little yes there are alot of hacks on this site i am trying to help you and you can keep the money i'm just trying my best
  • 2,071 Answers
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing
Hope this may help;
Regards,
VOTIT
Posted on Sep 06, 2008
    President:
  • 1,450 Answers
You will find all these so called experts are just trying to post a b.s. answer hoping you will rate them so they can get paid.I dont know anything about your machine so not gonna try. There are some very good experts on here,ALSO A LOT OF HACKS!!
    Genius:
  • 1,665 Answers
Download User manual for SINGER 7466 at link below. It may has usefull informations.
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/7466-_M
    Brigadier General:
  • 5,158 Answers
The only other solution short of finding the service manual is to go to the home page and search for repair shops in your area.
Robert
    Genius:
  • 1,269 Answers
Download the user's manual HERE for instructions on how to disassemble and the machine parts
    Master:
  • 638 Answers
Sewing machine question and answers.
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
thanks.
please do rate the solution
  • hemant somaiya
    hemant somaiya Sep 05, 2008
    Free workbook download link: Singer-14T967DC-Workbook.pdf (5547k) (This workbook will also be included on CD with purchase of this machine!)
    Fully Automatic Self Adjusting Tension System
    Set the dial to the type of stitch you choose, the Quantumlock™ 14T967DC will sew a perfectly balanced stitch on different fabrics with multiple thread choices. It will even sew from one fabric selection to another without additional adjustments. Sewing with different threads and fabrics has never been easier!
    Differential Feed
    Fully adjustable to ensure an even feed for perfect seams on every fabric-no breaking or puckering. It is also useful for keeping stretch fabrics and bias cut fabrics from becoming "stretched out".
    Cover Hem and Lower Looper Automatic Threader
    These automatic threaders make threading tight spots trouble-free.
    Adjustable Cutting Width
    A moveable upper knife cuts fabric for 5-7mm stitch width.
    Stitch Length Dial
    The Stitch Length knob is conveniently located on the side of the machine and can easily be changed to personalize the length of the stitch for all the sewing projects.
    Color-Coded Lay-In Thread Tension
    With complete, easy-to-read diagrams, this feature makes threading your Quantumlock™ a snap. Just follow the color-coded diagram on the machine for effortless hreading.
    Attachable Clean Pocket
    The attachable clean pocket keeps the sewing area clean by catching the trimmed fabric.
    Extra-High Presser Foot Lifter
    There are 2 heights to the presser foot lifter. The second height offers extra clearance, which is needed when placing multiple layers of bulky fabric under the presser foot.
    Automatic Presser Foot Pressure
    The Presser Foot Pressure knob is conveniently located on the side of the machine and is pre-set for most sewing needs.
    Tension Release
    Raising the Presser Bar Lifter releases tension on the threads, allowing for threads to easily be pulled through the threading system.
    Built-In Rolled Hem
    Switching to the rolled hem sewing mode is effortless. An easy-access lever moves the stitch finger in position for rolled hemming.
    Electronic Speed Control
    Guarantees consistent sewing speed with no jump starts.
    1,300 Stitches-Per-Minute
    Sews up to 1,300 stitches per minute.
    Portable
    The overlock has a built-in carrying handle, making it trouble-free to transport the machine. It also has a soft dust cover to protect the machine when not in use.
    25-Year Limited Warranty 30-Day Money-Back Guarantee*
    Put your mind at ease...with a 30-Day Money-Back guarantee and a 25-year limited warranty it is easy to see why SINGER™ is the consumer's choice. More people own SINGER™ machines than all other brands combined.
    STITCH FEATURES BENEFITS
    5-4-3-2 Stitch Configuration
    14 different stitch types ensure the perfect stitch, regardless of the project. The complete tension set-up for all of these stitch configurations is achieved with just ONE turn of the Automatic Tension System dial.
    Triple-Cover Stitch
    For exquisite seams with a truly professional look. This innovative stitch provides a 5.6 mm professional and creative triple topstitch to sewing projects. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Double-Cover Stitch
    This is professional Cover Hem stitch is a necessary requirement for today's sewing. It is often seen in ready-to-wear garments or as a decorative accent to many types of projects. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Chainstitch
    This stitch is suitable for straight seams or for topstitching with decorative threads. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Five-Thread Stitch
    Makes strong durable seams. This stitch is suitable for woven fabrics and provides a durable seam for heavy weight fabrics such as denim and terrycloth. Using this strong safety stitch eliminates the need to reinforce the seam with a conventional sewing machine straight stitch. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Four-Thread Ultra-stretch Stitch
    This stitch is a favorite when sewing a knit fabric because the stitch stretches as the fabric stretches. This allows for neat and professional finishes that will not "pop" when the fabric is stretched. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Three-Thread Overlock Stitch
    This Three-Thread overlock stitch provides a wonderful professional seam finish to woven fabrics. It is beneficial in preventing loosely woven fabrics from unraveling, and it offers unlimited decorative capabilities. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Rolled Hem Stitch
    By simply moving the stitch finger knob, the Quantumlock™ is converted to the rolled hem sewing mode. Beautiful Three or Two-Thread rolled hems can be created to add an elegant fine finish to table linens, scarves and much more. Properly set all tensions with just one turn of the Automatic Tension System dial.
    Flatlock Stitch
    For true decorative flair on any project. Special decorative threads can be used to add texture and a dramatic embellishment effect. Properly set all tensions with just one turn of the Automatic Tension System dial.
How to change light bulb on my singer 7466 sewing machine
Here's a manual for your machine:
http://homeappliance.manualsonline.com/manuals/mfg/singer/7466.html
Didn't find instructions re the light bulb but best guess is that the cover on the left side needs to be removed. Looks like there may be a screw that holds the cover in place.
Jun 11, 2016 | Singer 7466 FS, Free $30 Car Vac* FULL...
Can the female part on the sewing machine that the control foot male end clicks into be replaced, mine snapped off
IF YOU SEND A PHOTO IT MIGHT HELP ME TO KNOW WHAT YOU NEED. ANYWAY, A REAL GOOD SOURCE TO GET ALMOST ANYTHING IS: http://www.sewingpartsonline.com/singer-7469q-sewing-machine-parts.aspx
Nov 23, 2014 | Singer 7469Q Confidence Computerized...
Wiring diagram model 7466 i am trying to reconnect a foot pedal on my singer sewing machineu
The foot pedal is generally plugged in on the right side of your machine. There should be a hole that matches the end of the plug. The user's manual is available as a free download on Singer's site.
Sep 22, 2014 | Singer Sewing Machines
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
Just bought a used model singer 6233 need to know where foot pedal plugs in
The Singer 6233 was one of the models that briefly were made using air-powered foot controls. So you aren't looking for a traditional electrical connection. Instead, your pedal cord's female end will connect onto a black male nipple, that sticks out on the right side of the machine (the side with the handwheel). Just push it on until it feels snug.
May 10, 2010 | Sewing Machines
I have a 7466 Singer sewing machine. No matter how I adjust the thread tension, the top thread always pulls the bobbin thread through to the top. I am doing thread painting. The feed dogs are lowered and...
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Mar 28, 2010 | Singer 7466 Mechanical Sewing Machine
IMITATION LEATHER
Depending on the overall thickness of the proposed job, this should be fine provided you bear a few things in mind, and monitor progress.
Use a new size 14 or leather needle, and be prepared to renew needle several times depending on the size of the job........start the sewing by turning the handwheel to create the first stitch and run at low to moderate speed
.....if the machine feels like it is struggling from the outset, do not continue.....
if it runs fine and only starts to labour after a while, the needle will have become blunt...replace it.
For each new seam, start by turning the handwheel manually, just to get things started.....you may also find this helpful at the end of seams for the lock stitch
Also...
The presser foot tension may need to be relaxed a little depending on the overall thickness of the job
Feb 09, 2008 | Singer 7466 Mechanical Sewing Machine
Singer 7466 Mechanical Sewing Machine Logo
653 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
