Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-151 How do I select #'s 26 and 39? I pressed the start button and there is a 15 that appears.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
E7 15 copy lamp disconnection : Copy Lamp Drive Circuit
you need a tech to replace the circuit board for the scanning lamp
can not be reset
26 = 2 & 6
39 = 3 & 9
Posted on Sep 05, 2008
Sharp AR 151 E7-15 error
copy lamp disconnection trouble - copy lamp or cpy lamp drive circuit (inverter PWB) trouble copy lamp disconnection. If lamp does not light when you power up machine, the lamp is burned out or board is bad.
Aug 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-203E photcopier is flashing a number then what appears to be the letter H, it had a paper jam but thats now sorted but it wont do anything!! help
on the control panel press clear button then interrupt button then zero button then interrupt button the display will change, then press 1 then 4 then start button then clear button (or power off) if you are blinking H then 5 it means you have had several jams in the fuser
Jan 07, 2010 | Sharp Office Equipment & Supplies
HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS CHANGED. CODE H3-00 STILL APPEARS.
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Nov 04, 2009 | Sharp AR-5320 Black and White Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Sharp AL 1644
here is the fix: Press "C", press the exposure button (below the picture of the little man), press "C", press the exposure button. When you do this all the indicator lights will turn off. Now input "24", press the green start button, input 07, and press the start button again. Now turn the copier off and back on with the power switch on the side.
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "24", "Start Key", "7", "Start Key"
Sep 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-151
Try this sequence
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "26", "Start Key", "39", "Start Key"
there IS another subcode besides E7 try holding the stop or start or clear key you will probably see some different #'s
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-151
E7-03 LSU problem (laser unit) E7-04 CCD white level problem E7-05 CCD black level problem E7-12 Shading problem
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
177 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
