Question about Palm Tungsten T5 - Multilingual Handheld
Fatal Alert I tried to "open" the e-pocrates from my pda (palm one t5) and all I get is this fatal alert message that says, "DataMgr.c, Line:11231, index out of range"
  • Anonymous Mar 16, 2008
    when I hot sync it is unable to download to memory card says it does not have software to access card
    Novelist:
    Champion:
  • 277 Answers
Here is Epocrates answer: "... A fatal error when opening the Epocrates application typically indicates that one of our database files has become corrupt. HotSyncing again may restore functionality. If not, uninstalling and reinstalling our application should correct the problem. Other Fatal Error messages relate to not enough free memory on your mobile device for a complete installation or, your mobile device does not use the correct Palm OS version. Please verify you meet our minimum system requirements by returning to our web site, click Support, and then click System Requirements by your Epocrates application. Delete Epocrates Palm/Win from your mobild device. On your mobile device, tap the clock (located upper left corner of your screen), tap App then Delete. Select the following files (one at a time) then tap Delete. You may not see all of these files on your mobile device. It may take several minutes to delete a file. The file will disappear from the program list or your mobile device will turn off when complete. See Frequently Asked Questions 484 for instructions to preserve your notes * AutoUpdate or Libaupd * Cholesterol * Compendica * DocAlert * DocMemo * Drip Rate * Epocrates * Epocrates Dx * Epocrates ID * Epocrates Lab * Epocrates MedTools * Epocrates Rx * Epocrates MTH * Epocrates Startup * Epocrates Tables * EpoxLaunch * Fahr/Cels * HTN Ref * Insulin Calc * MedMath * MedToolsHack * MobileCME * Natrecor * OnBoardAU * Tutorial * UpdateEmail * Version-ep22 * Any file ending in NC-2 * Uncompressor * Any file starting with SMSH * Any file starting with ID and ending with NC43 Tap Done when finished. Disable the Epocrates conduit. On your computer, click on the HotSync Manager icon in the lower right hand corner of your system tray then click Custom. Double click Epocrates , select Do Nothing and check Set As Default. Click OK. Double click System, select Handheld Overwrites Desktop and check Set As Default. Click OK then Done. HotSync your mobile device to your computer. Locate and double click Epocrates2PalmW.exe to reinstall Epocrates. If you cannot locate this file, return to our web site, click My Account, login, click Epocrates Download then follow the remaining on-screen instructions. ..."
Posted on Nov 08, 2005
Everytime I use the search fuction I get a fatal alert message
Make sure you have over 25% remaining space on your HandHeld and try again. Otherwise try a hard reset: Hold down the power button and click the reset button.
For more help:
admin@dec-help.co.cc
DEC Electronics Limited
www.dec-help.co.cc
Feb 26, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Fatal alert
This is a common problem with the Tungsten line, You can try doing a hard reset. This worked for my E2. If that doesn't work, the battery must be removed for a few hours. Although it still may not work after the battery removal.
** To preform a hard reset, hold down the power button, and push the reset button on the back of the unit. The top of your stylus unscrews to expose a "plastic pin" for this purpose. Keep holding down the reset button while the unit reboots. You should see a palm screen displayed while it restarts, let go of the power button and follow the instructions. Pressing up on the pad ring should erase all data.
Feb 20, 2009 | Palm Tungsten T5 - Multilingual Handheld
Tungsten e2
Take a look at your address and birthday sections and see if you can find duplicates bith in your PDA and you desktop.
Jan 05, 2009 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Getting a fatal alert
Make sure you have over 25% remaining space on your HandHeld and tryagain. Otherwise try a hard reset: Hold down the power button and clickthe reset button.
For more help:
www.dec-help.co.cc
Aug 14, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Fatal alert
I've had the same problem. Mostly I've found that it is a corruption with the documents to go database. (I'm using version 7). To make the error go away, you can delete the docs to go application and the documents and then reload both (make sure you set the desktop to override the handheld until you've got the docs back on your PDA.) I'm considering upgrading to docs to go v10 to see if this will fix the problem ...
Jul 23, 2008 | Palm Tungsten T5 - Multilingual Handheld
Fatal alert
Do you have an MP3 installed on your Palm?
You might have to reinstall it.
Jun 13, 2008 | Palm Tungsten T5 - Multilingual Handheld
Note pad
Maybe some other program has modified the Notepad program. Back up all your files and do a hard reset. Still not work, call palm...
May 13, 2008 | Palm Zire 71 Handheld
Fatal Alert problem
We prayed and asked God to save the data even though we had to do a hard reset. Data was preserved entirely! For this we give thanks--and praise.
Rob Starner
Feb 19, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten T5 - Multilingual Handheld Logo
286 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
