Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printing broblem when I choose image quality A4 NORMAL OR FAST/PLAIN the letters are faint and lengthy. However when I choose image quality A4 FINE?PLAIN the printing is O.K. Thanks Christ
  • 1 more comment
  • oikon Sep 05, 2008
    when I choose image quality A4 NORMAL OR FAST/PLAIN the letters are faint and lengthy. However when I choose image quality A4 FINE/PLAIN the printing is O.K.
    Thanks Christ
    Thanks Christ
  • oikon Sep 09, 2008
    I have followed your guidance namely desired paper -plain,- printer head cleaning and update driver but the problem still remains
    Thanks in advance.
    Christ
    Guru:
  • 859 Answers
You may wish to Print [and also Bookmark this page] this particular solution by highlighting it and then printing it off using your Fine setting and plain or high bright paper, the one we know does work for you. When you see the pint dialog choose the radio button titled Selection Only by clicking on that little circle.
When ever there is a distortion of an image or letters in a document your driver is corrupted. And, simply updating a driver will not always resolve this issue.
In addition to the driver issue. You may also be exhibiting signs of a worn print head and differences between Canon factory ink (which is unique to itself) and a substitute ink (whose ink pigments are not the correct size in nanometers for the holes in the bubble jet. Or, this is also indicative of erosion of the bubble jet holes in the print head by the harsh pigments cause them to become out of round and more oval and this causes a lack of clear definition in letters printed.
In your case, the most prudent way to proceed is to perform the most simple solution first before engaging in the purchase of new print heads which can cost a good sum of money.
So, I would advise doing the simple tasks first in an attempt to resolve this problem. Then, I would encourage you to consider a new print head and ink cartridge later. More often than not, these things can be resolved without spending money, just time. But, this exercise does involve taking measures that are not all that time consuming, just lengthy and involved.
To resolve any driver corruption, the driver needs to be removed and your system registry needs to be cleansed of any remaining entries regarding the driver you've just removed. Unfortunately, not all drivers upon removal remove all the entries in your registry. This is pretty common in Windows.
I'll include the page urls when needed for all the software downloads for your printer to keep this as simple for you as possible.
Go to Start Menu, Control Panel, Add/Remove Programs and look for an entry for your Canon Printer, there may be more than one program installed as well.
If there are no entries for your Printer, go to Start Menu, Control Panel, Printers and Faxes and right click your printer icon. Select Delete and confirm to delete all files associated with your printer if you are prompted to keep them or not.
Remove your USB cable from the Printer or computer, which ever is easier to get to.
Before proceeding further Bookmark this page so you can return to this lenghty solution posted by Worldvet.
This is this page's url:
http://www.fixya.com/support/t1010779-printing_broblem
Now, restart your computer.
Once you have a new desktop get on the internet and go to this
solution's page:
Now visit this link below to:
Download and install this free Registry Cleaner (click on the download button in the top left) that has no Ads, nag screens or tricks, its clean and very reliable. It makes automatic backups for wyou.
After you have uninstalled the Printer and its programs, restart your computer. Then, run Registry Fixer and click on Fix. Now, restart your computer again.
Now, you want to download and install the printer driver and then the update to your printer. Your USB cable must be unattached during the install process and if you are prompted to do so, attach it the computer, by the installer and only attach it then.
To get to the download page for your Printer:
Go to this page: If 'Select OS is showing', choose Windows XP. These links below are FOR Windows XP so if you are using a different OS, Stop and post the OS you are actually using first . The Software listed further down appear to be OS independent but it pays to be certain first before causing further problems.
Download the first driver listed for your printer under Drivers
Once downloaded go ahead and install this driver, if it creates a subfolder or wants you to create one, but remember where this is for later if needed. Remember that you may be prompted to attache your USB cable during the install. If prompted to restart your computer do it when prompted.
After that success return to this page again. Again, select the OS as Windows XP.
Now, download the driver update. The second item listed under Drivers.
When you installed the driver if it created a directory to uncompress from, point Windows to that should Windows pop up and tell you new hardware has been installed and let Windows do its thing even though you have installed it already. This is just a fluke in Windows that has to be dealt with.
Now, should you choose to do so, download and install these programs that come or came with your printer originally.
If you were prompted to restart your computer again, do so and when you get your desktop back return to this page. Select the OS as Windows XP. and then download the programs below that are listed on that page under Software
Easy-PhotoPrint EX Ver.2.0.1
Easy-WebPrint Ver. 2.6.4
Easy-PhotoPrint Ver. 3.7.0
MP Navigator
Please keep me informed as to your progress and you can always reach me by using the Ask Me button on this page:
http://www.fixya.com/users/worldvet/
Worldvet
Posted on Sep 09, 2008
  • Canon Master
  • 1,879 Answers
Document printing or image ?
  • Canon Master
  • 19,396 Answers
It is either a faulty printhead or a defective cartridge. Start replacing the cartridge, if thet does not help you will need to replace the printhead.
    Brigadier General:
  • Canon Master
  • 3,614 Answers
First check the paper you are using, and i wnat to know if your are using an orig. ink.
let me know
thanks
  • micromaster
    micromaster Sep 09, 2008
    To specify the paper type for your printer, click
    Start, Control Panel, and Printers And Other Hardware (or Printers And
    Faxes). Right-click the icon for your printer and then click Printing
    Preferences. Select the Paper/Quality tab and, under Media, choose the
    desired paper type.
    and also try to do a printer head cleaning.
    if not working try to
    Update the driver.
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
I have an error msg saying load plain letter SSF 024-969
I guess that you normally use A4 paper. If this is the case you are most likely printing from a document that was created using the Letter paper size (typically a Word Doc of PDF file created in the USA). The solution is to reformat the document that you are trying to print, to A4. You may change the formatting of the document when doing this and page numbers may be incorrect when compared to the index and contents pages.
Oct 15, 2009 | Dell 2130cn Laser Printer
The print is faint. The lettering on the excel spreadsheet is Arial Regular 10, colour - automatic and normal font. However, the printed copy appears grey rather than black. Toner cartridge recently...
normally you go to printer settings and look for where it says page quality. make sure the page quality is set to normal or fine. this will make it black. if it is on a setting lower than this it will cause the printed document to appear grey.
cheers.
Aug 18, 2009 | Samsung ML 1610 Laser Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Printing too slow
hi it's normal to print slowly u can configure the printing settings to choose the printing qualtiy so if change ur printing quality to draft it will be faster but if u choose the resolution to be higher then the speed of printing will decrease and so on.
Jun 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Will not print A4
Go through the paper settings on the front panel of the printer and ensure the paper trays are set to "Plain A4".
I usually set "override A4/Letter = Yes" too as many programs / documents / PDFs assume US Letter size.
Jan 27, 2009 | HP LaserJet 4 plus Printer
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
