Question about OKI Office Equipment & Supplies
I need the bypass codes for resetting the toner sensor errors for an okidata c5500
Soulvisitor
  • 1113 Answers
SOURCE: Okidata C9500 DXN--Printing Issues
Your asking a bit much
1) - Power ON printer while holding both the + & - buttons until “OKIUSER” message appears in LCD.
2) - Press + or – button until “ENGINE DIAG MODE” is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or – button until “NV-RAM INITIAL” is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. .....
..........the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Posted on Nov 19, 2007
SOURCE: OKIDATA C3530 MFP with 980
buy a new fuser
Posted on Oct 07, 2008
  • 54 Answers
SOURCE: Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Posted on Mar 16, 2009
pdouglasss
  • 125 Answers
SOURCE: 540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
Posted on May 24, 2009
  • 1684 Answers
SOURCE: B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 07, 2009
How to reset this error code 094-322. Fuji xerox c5500
sounds like a toner error. i would call the customer support and find out. usually, if it is toner problem (low or empty), replace the cartridge and power-on the unit. that should clear the error. on some, you have to go in manually in the menu to clear it.
Apr 11, 2013 | Office Equipment & Supplies
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Hi moneybaggz52:
Symptom:
Cause:
Resolution:
CORRECT POSITION
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
Mar 16, 2009 | OKI C5100 Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Reset drums for c5500
I have the same problems many of you have with the Toner and drum error on my C5500N. I have not had much luck with Okidata support. I have had success replacing the chips in the toner cartridges. The replacement chips can be obtained from www.printerdoctor.com. They sell toner refill kits for the printer as well as chips for the toner cartridge and replacement fuses and rebuild kits for the drums.
Oct 06, 2008 | OKI C5500n Printer
Toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Nov 13, 2007 | OKI C9300 Led Printer
488 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
