Question about Belkin Computers & Internet
Encryption problems hello, i have just setup amy belkin f5d6231uk4 i can access my network but when i enable the wep encryption i can not access the internet on my laptop i have no idea hoe to use the "add a computer" on the install cd i have a usb flash drive and have tried to set up the network through windows but without succsess thanks for your time danny
    Scholar:
  • 65 Answers
You just have to enter the WEP encryption that you have configured on the Belkin router to reconnect your laptop back to the wireless router. To verify the WEP of the router:
  • Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  • You will get a login page. Leave the password blank. Click Submit .
  • On the left side of the page, click Wireless Security or Security below Wireless .
  • Take note of the WEP key.
  • Click Logout in the top right hand corner.
  • Posted on Sep 09, 2008
    Belkin router problems
    Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
    Thanks for using Fixya.
    Aug 03, 2010 | Belkin (F5D5231-4) Router
    Setting secured wireless connection
    You can enable WEP on your router.
    In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
    By default the username is admin and leave the password blank.
    On the Setup page, go to Wireless.
    Security Mode should be WEP then click Next.
    You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
    Save the settings.
    I hope this helps!
    Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
    I need to create a security password
    Have you checked the support site? There is an article titled Configuring Wireless Security that describes just what to do. You should not, however, use WEP encryption unless you absolutely must, since it is easily cracked.
    Sep 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    We formerly used a linskys router, How can we
    if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
    Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
    How do I put an encryption on my linksys router?
    Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
    • Enabling WEP or WPA on the Router
    • Enabling Wireless MAC filter on the Router
    • Disabling SSID Broadcast on the Router
    NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
    Enabling WEP on the Router
    Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
    a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
    b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
    Enabling WPA on the Router
    Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
    • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
    • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
    To enable WPA, click here.
    Enabling Wireless MAC Filter on the Router
    Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
    To permit wireless computers to connect to your wireless network, click here.
    To prevent wireless computers to connect to your wireless network, click here.
    Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
    Jul 11, 2009 | Linksys Wireless-G WRT54G Router
    Unable to encrypt router
    you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
    Jun 04, 2009 | Belkin (F5D5231-4) Router
    How do I security enable my Belkin router?
    Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
    Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
    Click Security under Wireless menu.
    Under Security, Select 64 bit WEP (or 128 bit WEP).
    Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
    Apply the settings.
    Please write down the key – You will need it later to configure your wireless computers with the same key.
    Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
    /regards
    Teis
    Jan 01, 2009 | Belkin (F5D6230-3) Wireless Router
    How to make it a secure network
    Malicious users can easily capture information transmitted over an open wireless network. To prevent unauthorized access to your personal information it needs to be encrypted.
    To secure your wireless network some kind of encryption must be enabled on that network, whether it is WEP, WPA-PSK (or MAC Access Control List). The most used method (and easiest to configure) is WEP.
    Configuring WEP:
    1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
    2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
    4. Click Security under Wireless menu.
    5. Under Security, Select 64 bit WEP (or 128 bit WEP).
    6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
    7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
    Any other questions, let me know.
    Cheers,
    Nick
    Nov 18, 2008 | Belkin (F5D7230-4) Router (587009)
    How do i enable wep security on my belkin wireless routeron my pc & what do i do for 2 laptops
    check
    Setting up wireless security
    Belkin : Support : Configuring Wireless Security
    Enable wireless and wireless security on your Belkin ...
    Generally access the router control panel panel putting router ip number on internet explorer bar. You will be asked for passwords. Check IP number and password for your model on manual.
    On panel go to wireless then security, you find menus at left and top bar of the router control page in internet explorer.
    Set encryption and input the password.
    Do save all command (button at bottom of page).
    set wep password also on wireless networked computers.
    Jul 07, 2008 | Belkin Computers & Internet
    Encryption
    The Access Point determines encryption. This is because the access point provides the path into the network. In infrastructure mode (all computers communicate through the access point) the AP is configured for 64- or 128-bit encryption. In 64-bit, WEP key 1 through 4 must be selected. In 128-bit, there is only one WEP key. The client computers must now be configured to the same WEP settings in order to connect to the network. If the WEP settings on a client are not correct, the client will show that it is connected to an access point, but no data can be exchanged, i.e.. no Internet browsing is possible, etc. 802.11b Ad-hoc differs only in that each computer must use identical WEP settings. There is no AP in the system to drive the WEP.
    Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
    Computers & Internet Logo
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
