Durabrand TV Model # BH200HD
Durabrand TV Remote device.....to change to a 2 digit station (24 for example) I have to first press the button with dotted lines and a slash through it. Otherwise, when I select change 24 it always goes to channel 2, not 24. I can of course scrool up or down one channel at a time. I hate having to do this and want to use a universal remote because it has much larger numbers and buttons than the Durabrand remote which came with the TV. When I select a 2 digit number (24) on the unversal remote it always goes to channel 2 just like the Durabrand TV remote. How do I use the universal remote to select 2 digit channels such as 24? The universal remote is a Phillips, SRU2103WM/17.
SOURCE: remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Posted on Sep 02, 2008
  • 146 Answers
SOURCE: problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Posted on Nov 10, 2008
  • 11800 Answers
SOURCE: Proscan model PS36700YX1
I'm assuming that the buttons on the case are working - in that case the fault is in the remote - the button pads have worn out or are out of place. You should try fixing it: open the remote (a screw and some clips on the periphery) take the rubber pad off and clean it thoroughly ; then wipe very carefully the board of the remote - use alcohol for that; wait for everything to be fully dried and reassemble the remote. If after that the buttons still don't work then you need a new one.
Posted on Sep 03, 2010
SOURCE: I can only change channels using the up & down keys on the remote button. But if i press the channel number, eg. Channel 17, if i press 1 and 7 on the remote button, it will not change channels. O
u have to press the enter button after entering the channel number
Posted on Mar 12, 2012
rstehlin
SOURCE: tv doesn't register remote presses
unplug tv for about 5 mins
Posted on Oct 20, 2012
How do I manually change the TV stations ??
You should press the prog: button < / > to change the channels stored in each program. The number of press will depend upon which program do you wish to see. It will be best to buy a remote control for this set, as this set will not have a Menu button on its front panel, as there is only four buttons on panel, as you indicates here.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
Jul 13, 2014 | Sharp Aquos LC-C3234U 32 in. LCD TV
Dish Network Remote Coltrol and durabrand model 1304D tv 13" need to program the remote please help
Hello
Three digit remote codes for Duraband are:-
042/ 053/ 046/ 206/ 805/ 906
Four digit remote codes for Duraband are:_
0189 0135 0157 0051 0189 0053 0227 0456 0042
NB: Switch OFF and switch ON your tv, with its front panel power switch, [NOT BY REMOTE CONTROL HANDSET]; each time before trying an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
ok.
Dec 25, 2010 | Durabrand DWT1304 13" TV
I have a quasar tv and Z remote how do i program it to my tv?
Tune the TV with the remote control provided with device
1. Power on the TV by pressing momentarily the power button
2.Select the menu option on the programs list on the remote
3.Using the navigation arrows to locate the channel options
4.The option of tune also indicated as auto tune is the function to select to program the TV
5.A press on the auto tune button would initaite a scan through the entire TV functionality,
6.The process should tune the TV in which time would acquire available signals either broadcasts or devices that have been connected to the TV would be recogsied as well.
7. Any TV broadcast signal would be stored in the TV memory making possible program broadcast after process is achieved.
Important note
The TV would only capture signals on subscription to broadcaster establishment. For example, after TV tune up, no shows available requires acquiring service from providers. Examples of which include Dish Network, Time Warner Cable, or Digital Subscriber stations for possible broadcast subscriptions
Dec 02, 2010 | Televison & Video
HELLO!.. I HAVE A DURABRAND TV. AND I HAVE NEED
Hello You just buy one Philips CL 034 model Universal remote control, which can be programmed with your Duraband TV. The porgramme codes are
0520 0115 0317 0916 0027 0447 0323
Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one othe other codes for your brand. Ok
Nov 27, 2010 | Durabrand DWT2405 24" TV
Ive lost my code sheet for my philips universal remote cl034 and i need the 4 digit code for my durabrand tv
DURABRAND .......... 0520 0115 0317 0916 0027 0447 0323
Direct Code Entry
button.
flashes.
Oct 13, 2010 | Televison & Video
I need set a universal rca control, to panasonic tv model pv-2032w
Hi! Here are the steps on hoe to program your remote control to your TV. I hope this helps.
Code List : 012,013,038,086
1. Press and "HOLD" CODE SEARCH.
2. Press and release the TV button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
3. Enter the three digit code.
4. Release CODE SEARCH.
5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Jun 28, 2010 | RCA Universal Remote Control
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Nov 17, 2008 | RCA Universal Remote Control
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=BH1304D&brand_pn=DURABRAND_BH1304D&mode=large&uid=11831222740150 Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Televison & Video Logo
Top Televison & Video Experts
