Question about Vtech EV2653 Cordless Phone (73507800685)
No long distance
I have the 2 handset/answering machine ev2653. I can no longer call outside if my area code. It worked up until 3 days ago. The other 2 phones in my house (non ev2653) work fine. It seems to have stopped working after I made a 3 way conference call. I have pulled the batteries from both handsets, unplugged the units from the phone jacks, and uplugged the base unit. The problem still exists after connecting everything back up. Thanks for the help. Jack
    Champion:
  • 277 Answers
Hi i dont think the problem are in the phones call your phone supplier and ask about it good luck
Posted on Feb 26, 2006
I have a phone it recieves calls but can't make them it was working until 2 days ago
Several things can go wrong. Do they need to dial an extension to access an outside line? Make sure they know this. Also, make certain to remove any area code in the menu settings. The phone could be trying to make a call, yet it dial the area code each time and screws up the PBX, so no outside line. There are more possibilities, but they require on site tests.
Jun 09, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
One handset of phillips SE155 Trio doesn't ring. As i baught this phone 4 months ago. was working fine. But from 2-3 days noticing that one handset doesn't ring. I have looked user manual properly, checked...
We have a phillips se155 phone with answering machine, but when anyone tries to leave a message it says there is no more room. However I have deleted all messages on it. I would be glad of any advice because I have lost the booklet that came with the phones.
Dec 16, 2010 | Cell Phones
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
Searching In The Display Window
I unplugged the base unit and took a battery out of the handset. I then put the battery back in the handset and replugged the base unit. This corrected the problem.
Jan 03, 2009 | Vtech EV2653 Cordless Phone (73507800685)
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
No connection
deregister headsets and then run register again
Jun 09, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Dec 19, 2007 | AT&T 5840 5.8GHz...
Ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
Aug 27, 2007 | GE 25951EE2 Phone
Vtech EV2653 Cordless Phone (73507800685) Logo
94 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
