Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mits TV problem
Did you get your TV fixed? If so what was the problem? Capacitors? Lamp ballast board or Light Engine?
    Problem Solver:
  • 6 Answers
I finally got my TV fixed, I had to replace two capacitors the ones that were bad seem to be the same ones everyone else is having problems with, they were bad when I pulled the board out, they read 3300uf 10v and I bought this kit at this site that came with the replacement ones which were higher voltage but they worked just fine, if you order the kit, it will come with a manual and a bag full of capacitors, but you will probably just need the two I replaced which read 3300uf 16volts. I bought the soldering tool at radio shack for $20.00 it came in a kit as well. that was it, so like I said the TV is well and running now, it's great to finally get to see out of it, good luck!
Posted on Sep 09, 2008
Jvc hd-52g886 wont turn on
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown should work again.
Things you will need.
1. A plastic flat end screw or any object with flat fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 23, 2012 | JVC HD-52G886 52" Rear Projection HDTV
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Samsung hlr5667w that won't turn on. Good lamp and ballast
Any light blink on the front. Whats the voltage to the ballast from the power supply. Common problem on these sets are bad lamp door switch. Try shorting the switch. Color wheel also is problematic but usually will be noisy and cause shut down. Check power board for swollen capacitors. Hope this helps
Nov 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Just because you have replaced lamp does not mean that this one is not Bad,Did your order orignal Sony Lamp? Also have you CK Ballast board it is what fires lamp? You could have Bad Ballast Go to E-Bay thats were i have found Good Deals on Lamps and Ballast Boards Find them on Auction ,Also your lamp should still be under warranty find out if so get another one CK power supply board look for any capacitors to be bugled/Puffed up on Top if they are they are Bad this can cause lost of start,and if you have a bad fan can cause startup failure.Fan that keeps Lamp cool.most have at least 3 Fans.Let me know if you need any more help Heres you another tipp fined out about warrant on your Light Engine Sony Had Alot of Bad Light Engines and has up warranty on Sets for this Part IT IS VERY Costly they start at $2,500.00
Aug 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD-62525 My tv wont work. new lamp does not work. have tried ever
I had the same problem with my 52". I had the error code of 34(lamp abnormal). I put a lamp in that I knew was good and changed the ballast with one that I knew was good and had 8 caps replaced on the power board(they where not puffed but did them anyways) and still nothing. light came on for 3 seconds and went off again and tv shut down with a red status light. I did some reading on other web sites and found that if the color wheel is bad the tv will not work. I found a light engine on ebay for a 100 bucks used and installed that and now it works perfect.
Feb 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Bulb firing, won't stay on
Try to clean the air filter it soubds as if that is the problem. Then try it aain. If you need further assistance let me know.
Jan 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replacment lamp
Check your ballast and air filter. I am checking to see if I can get some detailed info on your set. It is a WD52525 correct?
Jan 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
