Hp laserjet m1522nf
I tried to scan and it wasnt go through, instead the messages appeared on the printer screen is:"scanner error 5, turn off then on", i followed this instruction but still it wont go through. with this problem, i cant even photocoy any dox, it says "device is busy, try again later...
  • 2 more comments
  • Anonymous Jan 06, 2009
    scanner error 5 in m1522nf
  • Anonymous Jan 27, 2009
    I can't print anything.
    It says: "busy try later"
  • aposkont Feb 28, 2009
    Same problem scanner error 5 even when HP partner told me that they changed the scanner. I think they must replace the whole machine.
  • Anonymous Mar 13, 2009
    i tried to scan and it wasnt go through, instead the messages appeared on the printer screen is:"scanner error 5, turn off then on", i followed this instruction but still it wont go through. with this problem, i cant even photocoy any dox,
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Posted on Feb 25, 2009
    Genius:
  • 2,120 Answers
Known scanner issues by HP. It's probably uncomoical to repair.
Posted on Sep 06, 2008
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
Apr 20, 2012 | HP LaserJet M1522nf Multifunction Printer...
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Hp laserjet m1522nf. when you print it states scanner error 5 turn off then on
See my tips section for the solution to this. This error is covered by HP and they will repair at no charge for almost all M1522's ever made.
Apr 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
Scanner error 5 appears. Have done all the recommended things in the manual plus other things like turning everything off for the night, rebooting computer, etc. numerous times.
Sorry but I have a bad news. Scanner error xx means that the scanner lamp is not able to move and if it does it cannot go all the way by either something blocking it or a gear worn. In some cases it does like a humming or clicking noise. The printer need service, probably a new scanner. You can try an NV RAM: Turn it off and press and hold the down arrow and cancel. Then turn it on and wait for the message ''permanent storage init'' then release the keys and will get back to ready. If the error persist contact HP they are giving 2 years warranty from the purchase date if that message appear. Good Luck
Sep 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Al
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
I have a LaserJet M1522NF printer and it does not receive some faxes and gives me a error 79 message on the display screen? can some one tell me what this is? i usually have to turn it off and turn it back...
Hello KIM !
Try doing an NvRam (Hard reset)
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
Feb 25, 2009 | HP LaserJet M1522nf Multifunction Printer...
3,688 people viewed this question
jasbo
jasbo
