SOURCE: water pump replacement in a 2002 Mazda MPV
The reason is the water pump is driven off the timing belt, extra parts and allot more labor. No the eng does not have to be removed, labor time around 4 hours, parts about, about $125 US for parts, if it is a dealer add $75 US
SOURCE: 3 liter mazda mpv overheating
You probably never cleaned the cooling system out.
If you have not get it done by pros.
It seems something is blocking the flow. If the water pump went bad you will know. Rarely ever heard a impeller breaks off like you think. The bearings and the seal break first.
Check and see also if the heater valve is working.
As for the over heating even new thermostats fail. Reverse flush is needed or the procan measure the pressure in the radiator cooling system and edetermine if there is a engine pressure problem. Tools and experience is the key in the game of diagnosis.
wfg8.com
SOURCE: 1997 Dakota v8 water pump replacement steps
Hope this helps!
Common Steps
WARNING
Most cooling system hoses use "constant tension" hose clamps. When removing or installing, use a tool designed for servicing this type of clamp. The clamps are stamped with a letter or number on the tongue. If replacement is necessary, use only an OEM clamp with a matching ID.
Heater hose pipe O-ring (arrow): twist gently when removing or installing; check condition; lubricate with coolant before installing
CAUTION
Always wear safety glasses when servicing contact tension clamps.
3.9L, 4.7L, 5.2L, 5.9L, 8.0L Gasoline Engines
WARNING
Bolts may be of different lengths. Be sure to note their locations.
To install:
Water pump mounting hardware—4.7L
Use a prybar to keep the water pump from rotating while pulley bolts are removed
Bypass hose clamp (arrow) must be tended to before removing the pump
Water pump bolts differ in length; note check location before installation—3.9L, 5.2L, and 5.9L gasoline engine shown
After removing the bolts, pull off the pump and place it in a safe location
