Question about U-Line 75BWC
Thermostat thanks for the quick response. how do I easily get to the wires?
  • 1 more comment
  • jdodaro Sep 22, 2008
    I had someone out today and they did diagnose it as a thermostat. Said they need to now send me a quote for parts and labor to fix. What should I be expecting in the way of parts cost and labor? He made it sound like it was a very complicated thing to fix (i.e. needs to take the whole thing apart). Is this the case?
  • jdodaro Sep 24, 2008
    Thanks. How much time do you think it takes to fix (assuming they charge me by the hour). The guy on the phone made it sound very involved - i.e. need to take the whole thing apart because its a sealed system.
    Thanks. It's an 8 yr old U-Line 75BWC refrigerator. Not sure if that is a standard stat or not.
If a standard stat, would take me about 40 mins to do including testing. normally an easy job
Posted on Sep 24, 2008
    President:
  • 1,462 Answers
Stat is immediately behind the temp setting knob and inside a housing. prize off the knob and the housing is normally held by a couple of screws. take the housing off and stat will be in view
Posted on Sep 06, 2008
  • douglas smith Sep 24, 2008
    i'm in UK not US so can't give you any guidance on cost. in UK part cost would be about £17 and labour about £40 tho stat costs do vary a lot
The thermostat on the wall is not working-no response to pressing any keys
Hi John:
I'm confused. Thermostats on walls typically control room temperature, and the thermostats for water heater tyemperature are typically set where they can not be easily adjusted. Can you tell us what make and model of heater you have, and what you are trying to do? We'll try to help.
Apr 03, 2015 | Water Heaters
I have 4 wires at thermostat, g, b, w, y. The old thermostat was removed before I owned the house. I would like a wiring diagram so I can trace the wires an know how to hook up. Thx. Ken
Trace the thermostat wires into your furnace and write down which color wire ties on to which letter at the furnace terminal strip. The HVAC color code is - g (Green) = house fan b (Blue) = auxiliary w (White) = heat y (Yellow) = cooling. If you need anything, let me know. And please vote on this response. Thank you.
Roger
Apr 03, 2011 | Heating & Cooling
Push start button on dryer. No response. I can hear the timer start (so it must be getting juice) but the dryer does not start. Your thoughts. What are the likely suspects for part replacement. ...
Unplug Electric or turn off gas before testing. Check to see if wall outlet has 240 Volts if electric. If not, that may be your problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Most parts likely to fail are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the part that fails to test properly for continuity.
Good Luck
Aug 30, 2009 | Kenmore Dryers
Brivis Ducted Heater works Non-stop
When you disconnected the W wire, was the R wire hooked up? If so then you either have a bad tstat or the R and W wires are shorted together.
Jul 23, 2009 | Honeywell Heating & Cooling
Maytag fridge getting too cold
what happens when set on the warmest setting? still too cold then I'd think it was the thermostat. Good luck
Jul 03, 2009 | Freezers
Robertshaw 9600: Temperature rises too high, fan doesn't stop.
It sounds like the thermostat is wired improperly. One quick was to check is by finding breaker to unit and shutting off power. Go to thermostat and remove from wall take all wires off thermostat besides wire going to R(might be RcandRh) and C(which is common) Tape all bare wires removed with electrical tape. Now go back to the breaker and turn power back on. Nothing should be running at all. Take a voltage meter and measure the voltage from R to W(which is heating). If you read 24V then the thermostat is open and not calling for heat. Now turn the thermostat up so it is calling for heat. You should read 0V from R to W. If this checks out your thermostat is probally fine. You can check the fan the same way by going from R to G. In auto you shoul read 24V from R to G and in th on postion you will read 0V from R to G. If the thermostat checks out then the problem is probably at the furnace or rooftop. Either with the thermostat wiring or the main board acting up
Jan 19, 2009 | Heating & Cooling
Whirlpool gas dryer- Series MK1159224
Just a quick thought...make sure that your gas shut off valve is ALL the way open.
In answer to the thermostat question, if the thermostat has completely failed, (open circuit) you're correct, there would be no heat at all. The thermostat contains a tiny heater, controlled by the heat select switch, for instance, if you set the switch to "low heat" the thermostat heater will turn on, applying heat to the thermostat, which means when the main heat turns on, the thermostat will cycle off quicker, because although the air temp may be, say...120F, the thermostat is at 160F. So, that being the case, you could possibly have a problem with the temp switch applying voltage to the thermostat heater constantly, and excessively. Or, the thermostat could just be cycling too quickly. This could be tough to pinpoint exactly without taking some voltage readings with the machine running....one way to check the switch is to remove the two small wires from the thermostat, (leave the larger wires on) and see if it heats properly, that would mean the switch is bad. Please remember to unplug and verify that there is no voltage with a meter before messing with any wires. Hope this helps narrow it down....
Sep 15, 2008 | Whirlpool LGR7646E Dryer
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Refrigerators Logo
129 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
