Question about E-Machines eMachines Desktop PC
Ethernet not working
My ethernet isnt working on my w3400. Have updated drivers. Is there anything else i'm missing?
  • 1 more comment
  • SherriCagwin Sep 05, 2008
    contacted provider and still nothing :(
    yes i have all new cables, modem is working properly,renewed my ip adress, contacted internet provider all is working as it should.
    i replaced the card also
    President:
  • 1,263 Answers
Have you checked the chord for connection? is your modem/router working properly? iwould check these first. then if they are working go to your connections tab and click on it. then click the repair tab this should. renew the IP address. if this doesn't help contact your service provider because then it is a problem with authorization to the net work. good luck please rate this
Posted on Sep 05, 2008
  • Ronald Mueller
    Ronald Mueller Sep 05, 2008
    have you tried all the options i gave you?
  • Ronald Mueller
    then the problem lies in your ethernet card inside the tower. this is a circuit fault and needs replacement. can you please change the rating to helpful thanks.
Ai intsalled new Os in my pc its a downgrade exactly gom windows to 7 ultimate but theres is several driver are missing the most i,mportant its the ethernet driver , please need you to fix it
open device manager, and go to network adapters and double click on the ethernet one. Then, go to drivers and click on update. This'll work for all the drivers missing
Jul 19, 2014 | HEWLETT-PACKARD Hewlett Packard HP Probook...
Automatic updates/ network adaptor goes missing / magically returns after system restore
Where is the Network Adapter originating from? Windows? If the Update is a Windows update, Hide the update. It may be an error, it's happen to me on a HP Network Adapter, When I installed it the Ethernet Adapter would not work, I rolled-back the driver on the Ethernet Adapter and it worked perfectly. I "Hide" the Windows update in Windows Updates.
Feb 23, 2013 | Broadcom NetLink Gigabit Ethernet
Pressario f500 wireless stopped working and isnt even recognised
Make sure that the wireless switch is on. If it is, connect the portable via ethernet on your router then update the wireless card driver.
1. open device manager 2. right click on the device driver 3. choose update
Jun 25, 2011 | Computers & Internet
Upgraded to windows vista. my Ethernet driver is missing. Where can I find the download for it. I have e machine. T6426
The generic Vista Ethernet driver should work. The only driver downloads I could find for your model are for Power DVD and the audio driver for Windows XP.
You may have to borrow a USB network link (wireless or Ethernet) device and use it to go to Windows Update. Select the Optional updates and you may find a driver for your onboard Ethernet there. Another possibility is to download the E-machines hardware detection utility on the page referenced in the previous paragraph - this will tell you who made the Ethernet chip and what model it is so you can download the driver from the manufacturer. You may also find this information in the System/Device Manager hardware list.
Jun 06, 2011 | eMachines T6426 PC Desktop
Ethernet light does not come on cant connect to internet
Try replacing the ethernet cable, if that doens't work then try to reinstall the driver, if that doens't work then that means the ethernet port could be defective.
Feb 28, 2011 | Computers & Internet
Missing video controller,multimedia controller,smbus controller,pci controller,ethernet controller
the driver should be on the disk supplied by your isp internet service supplier
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
hope this helps
Jan 13, 2011 | Computers & Internet
Why is my ethernet driver missing ? where can i get an update done from ?
Well, there are a lot of reasons to cause your driver missing or outdated.
As to the solution, I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best regards!
Nov 16, 2010 | NEC 82559-based Fast Ethernet Adapter
Installed new windows 7 and our Documax A3300 will not print invoices
well thats because the driver is missing or isnt compitable with windows 7,, to verify this right click on computer, click properties and then device manager,, you will notice that there are a few (at least 1) device with a yellow highlight Or unknown Device ,, that means that the driver isnt installed or isnt compatible with windows 7, Now There is a chance it can be fixed and this involves using the windows up date software..
Click Start, then windows Updates, Check for updates and Install All UPDATES INCLUDING Optional Ones.. The drivers are found in the Optional Updates..
Of you can contact the manufacturer of the Matrix Printer and Inquire If They Have A windows 7 or windows Vista Driver (Windows Vista Drivers Do Work in win 7 "Most Of The Time") and you can get it from them,,
I did check their website for it
http://www.amtdatasouth.com/support-1/downloads/drivers/
but did not find a windows 7 driver (Its possible I might have missed it Please feel free to check),, so your best best is the windows Updates Or Contacting Them..
Here is there contact Info
http://www.amtdatasouth.com/contact-us/
Oct 13, 2010 | AMT Datasouth Documax A3300 Matrix Printer
The camera turns off when the usb goes into the camera so it can't recognize it to download anything.
the reason it turns off is because it's going into "PC connection" mode this is normal. the reason it doesnt recognize it is because your most likely missing the camera drivers. it should have came with a CD with the drivers on it. Here is a link to the driver page for your camera. Kodak easyshare M883 drivers and firmware update you could also update the firmware if you havent already done so. the new firmware update fix's some stuff with the LCD screen while charging thru the USB cable this might also help you if the missing driver isnt the problem! Good luck i hope i helped!
Aug 12, 2010 | Kodak EasyShare M883 Digital Camera
I had to reinstall the operating system on my computer and I have no sound at all. It says I have no sound device installed and I used the disc that came with the system. What am I supposed to do? It is an...
I can get you the sound driver or send you to the place of downloads but I need to know which emachines model is it. Is it a latop or a T series desktop and so forth?. You by installing the Operating system removed all drivers and need to install them all like audio, video, ethernet ,and many others usually. If you right click on My computer and select MANAGE and then click on the left under DEVICE MANAGER you can see anything with a yellow exclamation is a missing driver that your computer needs. An easy way if you allready have the ethernet driver and internet access is to to WINDOWS UPDATE but select the CUSTOM UPDATES not the EXPRESS option and then you can check if it finds any hardware drivers or updates , usually windows update is very smart and gets alot of missing drivers you might have missing. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 11, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
35 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
