Question about Canon PIXMA MP760 All-In-One InkJet Printer
Prints colour but not text ip4000 I have not used my inkjet printer for over 18 months. I have just replaced all cartridges but the printer does not print black text. I have tried the deep cleaning for the nozzle about 5 times but this makes no difference
  • Han_Teunisse Feb 13, 2009
    Yes, I have the same problem. My printer (MP760) prints colours but no black. Replaced the Printer Head, but that didnĀ“t solve the problem.
    Please advise how to solve this problem?
Prints colour but ne text
Epson printer
Posted on Dec 08, 2008
OK Ashok421
This is a suggestion only.
Disclamer, If you do the suggestions below, then it's your fault if you muck up your printer head further, not mine, but they worked for me.
OK its school time.
It could be dried out ink in the channels, the ink flows out of the clear ink cartridge onto a gauze, from there it flows through passageways to the ink jets, where it is spurted onto the paper.
OK its Dr time
If the ink has been alowed to dry out because of lack of use, the longer the printer sat idle, the worse the drying out becomes.
OK its fixit time
So I can only recomend you take out the ink tanks, then lift up the ink base securing leaver to release the ink cradle, take it to your sink and get rid of any ink by turning it upside down, then right it. Next get some blotting or kitchen towel and see if the dry towel will "sponge" the ink out.
If that dosent work, wet the kitchen towel with hot water, then sit the whole unit on the wet towel and allow it to try and soften the hardened ink, (you might have to let it sit there for a few hours).
If the above dosent work then stronger measures are call for.
I heard that Windex, window cleaner might work, No guarantees.
OK its Crowbar fix time.
Fill a syrenge with warm water and spirt it upwards into the jet area itself, then sit it back on the kitchen towell. Do the same from the top ink input end, DONT touch the syrenge to any surfaces or you will scratch or break the unit.
You might have to do this a few times before the ink can flow freely.
There are now 3 other posibilities left, 1st the ink has dried out to a brick like substance, or 2nd the ink jets are fried trying to spurt ink that wont spirt, so the ink goes hard as a stone, 3rd the wires in the flexable membrane has fried. (happenned to me during a very long printout).
After cleaning the ink head, turn it over and look for a pinhead size blackened hole, through the flexable membrane, you could try and bridge the wires if you were technically savy and had experience with SMD devices, but unless you know what you are doing, ..........
If that wont work, count to 1000 and buy another ink doover.
My enquiries today produced a figure about $160 australian. (yep a ripppp offff)
LEAKING INK fix
You have put a new full cartridge in the printer, and within an hour it is empty.
The ink in a mess all inside the ink wells, remove the whole unit and wash in running water.
Dry it in the sun, then take it back to the printer.
Where the opening of the new ink goes is a biggish soft black rubber seal.
Remove the black rubber seal, get a coupple of "ire-lets", they are used in strengthing A4 paper sheets placed in a leavered file,(they look like tiny donuts), then place 2 over each leaking black post.Then put the rubber seal on top of the black post.
This rases the black rubber seal so it will sit snugly against the ink tank(s).
Posted on Oct 06, 2008
My canon PIXMA iP 4000 does'nt write out the colours, only black.
Use the Canon software to check the ink-levels in the COLOUR cartridge. If empty, replace it.
Use the Canon software to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are not spraying ink onto the paper.
Feb 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I have an Canon IP4000 printer that is not printing black text. It is printer colour but not black. I have replaced all the ink cartridges but only colour is working. Please help!!
pretty familar with that printer and if you have new cartridge check the head cleaner. If you clean the heads a couple of times that might unclog the black cartridge. Check inside your settings. I know you can turn the color completely off with that model but am not sure if you can turn the b+w off.
Jan 21, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Inkjet cartridges dry out prematurely
You need to run a page of print at least once a week. This should keep things moving
May 06, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Colours are not true, grey is brown
You are getting leakage from one color cartridge to another. Do deep cleaning and run nozzle check. You may have been using non-Cannon inks. They can corrode the ink cartridge seats due to inferrior quality ink. You may need to replace the print head. Check out Cannon web site under this printer support. Print head is in the $50 neighborhood.
Feb 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 has five cartridges 6BLK,e3BLK,6y,6m,6c
You may want to puschace and use a cleaning cartridge but positive results are not guaranteed. It depend how bad your print head is clogged.
The cost is about $5.
Google it (canon printer cleaning cartridge)
Nov 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer does not print colour
Do a deep clean and consider replacing the cartridges with OEM
Nov 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printing quality suddenly deteriorated
You could have printhead problems but I would offer that you do a deep clean and consider replacing cartridges with OEM
Nov 13, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Text is usually black. I am guessing that you are either simply out of black ink or the black ink cartridge is bad. If you do have black ink, try running a cleaning sheet through your printer. The steps on how to do this should be in your manual. Try replacing the black cartridge.
Apr 22, 2008 | Office Equipment & Supplies
IP4000 Color Printing Problem
If you have a monochrome option, I would use that.
I'm guessing that your old black and white photo's (which I'm thinking you scanned in may have a sepia tinge which the printer is emphasizing, and if you only want black/white prints, no need to print with colour.
Mar 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
132 people viewed this question
old marine
old marine
