Question about Intertherm Heating & Cooling
Someone has an Intertherm outside 3.5 ton a/c unit for sale but doesn't know anything about it Model 5SQD-042KA Serial S5A070500546 Can you tell me how many SEER, heat pump or not, age Thanks Ruth SherwoodTrio@aol.com
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
There should be a square sticker or metal plate that tells you the model # the #'s that comes close to the multiplecation of 12 =to tonnage,example ( asbv036g-1 the 36 = 3 tons 12x3=36 (gdhe420-1 = ==3-1/2 tons cooling 12x3 plus 6-1/2 ton = 3-1/2 tons the serial # tells the year it was made.....080808 , the first 4-#'s tells you the month--- for 4 #'s this is aug.- year 08 !
Posted on Sep 05, 2008
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
WHAT SIZE IS HEAT PUMP Q3RA-036K
Hello, this is a 3 ton unit. There are 12,000 btu per ton. The number 36 in the model number represents rhe tonnage of the heat pump, so 12,000 x 3 = 36,000 which is 3 tons.
May 09, 2012 | Heating & Cooling
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Intertherm P3RC-036K Air Conditioner
LOOKING FOR YEAR OF MANUFACTURE FOR MILLER MODEL P3RA-030K SERIAL P3D030400057
Your unit is April 2003. So it is 8 years old. P3D is model ref 0304 is year/month of manufactor. You also have a 2.5 ton system. Hop this helps. Info verified through local Intertherm distributor.
May 16, 2011 | Intertherm P3RA-030K Air Conditioner
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
High head presure , not sure if condenser fan motor is correct,model number is s3qa-042ka-3.5 ton
There is a valve inside of most compressors that when it fails (sticks) it either fails high or low. If you have the wrong size of fan it may have overheated. You can try de-energizing the unit, then lightly tapping the compressor in various places with a rubber mallet. I know it sounds goofy but it might save you a repair bill.
Sep 10, 2010 | Intertherm Heating & Cooling
I have a interterm air conditioner with a number 702338910789, and I would like to know what size it is? e-mail address aslin@shaw.ca
This loks like a serial # made in 10-07-89 now you need the model # to tell what size. The model # usually has letters followed by the multication # of 12. Which =-1-ton like ""gud36a-1" in which 36 = 3 tons of cooling this is on the outside unit Now what if it says "dar42a-1..... this is a 3 1/2 ton of cooling in major cases...
Dec 21, 2009 | Intertherm Heating & Cooling
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
We installed a 4 ton downflow coleman air handler with evap coil Model number 1854s2m we did not change out the outside unit. the outside unit is a 13 year old 3 1/2 ton intertherm condenser the system is...
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
