Question about HP LaserJet 4 plus Printer
Laser Jet 4 plus can't print with USB?
Hi Sir/Madam,
The laser jet 4 Plus worked well with my old computer. After I switch to my new computer with XP installed, and bought a parallel USB cable, it printed only a line of symbols on the paper only.
I bought a serial USB cable, it still doing the same thing
What has gone worng? Please help
thanks
  • lubo438 Sep 08, 2008
    I don't understand the compatibility issues, I look up HP web site and could find any driver for USB port for this model, any advice?
    A CD comes with the USB cable has only drivers for older OS Win Me, 2000, etc. nothing for XP or Vista
    The serial USB cable doesn't have any software come with it.
    thanks
    New Friend:
  • 159 Answers
1.check the cable compatibility
2.install the driver HP laser jetIII
Posted on Sep 06, 2008
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Hp laser jet 4 plus prints only half the page then black pages then the other half with cryptic writing on pages over text
What I would do, is go out the www.hp.com/#support.
Download the latest drivers.
Install them and start printing again.
If it fails again, print a config page. If that prints correctly, that tells you that the printer is working correctly. Problem is with the interface. If you are using the parallel interface, try a different cable.
If you are using the jet direct try a different one and a different cable.
Could also be a bad formatter.
Good luck
Feb 18, 2011 | HP LaserJet 4 plus Printer
Hp laser jet 4 plus
what is the issue? All your post indicates is "HP laser Jet 4 Plus" As outdated as this device is I have used it for years, since 1997 at least, Biggest problem I ever had was a drum problem.
Oct 16, 2010 | Office Equipment & Supplies
I have streaks on my print outs from hp laser jet
check your toner cartridge, check your fuser rollers and check your transfer roller assembly.
Sep 23, 2009 | HP LaserJet 4 plus Printer
HP Laser Jet 4 Plus to iBook G4 serial to usb
serial to usb is not plug and play so i don't believe this configuration will ever work.
parrallel to usb is plug and play 90% of the time.
purchasing and installing a port replicator is a 100% fix as long as the formatter on the printer is working properly. good luck!
Aug 21, 2008 | HP LaserJet 4 plus Printer
Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Aug 17, 2008 | Emulex NetJet (NJ01B-NTplus) Print Server
Hp Laser jet 4 plus
Bad toner cartridge or fuser is burned out.
Aug 15, 2008 | HP LaserJet 4 plus Printer
HP Laser Jer 4 M plus
How is the machine connected? try changing the data cable if this doesn't work then shutdown your computer while the machine is on and reboot as if it is connected via LPT port some systems like to have the printer on before the computer.
Try this and I hope it helps if it doesn't then you might have a faulty print formatter board.
Thanks J
Nov 20, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
195 people viewed this question
Ben Johnson
