Question about Refrigerators
I have a samsung RS21DGRS and it keeps makung a wurring noise from inside rear of the fridge compartment and now the water dispenser has stopped working .
  • grmcmahon Oct 28, 2008
    Hi I have the same problem, water dispencer not working. No noise do. Replaced filter, checked water feed, water in pipe & pump seems to be working.
    New Friend:
I just called Samsung and they are sending a repair man, free, even though mine was built in 2006. They were keen to stress this was a one-off and there would be no further support afterwards, but still. Well done Samsung!
BTW - From the UK the new number to call is 0330 7267864
Posted on Nov 11, 2015
    Sergeant:
    New Friend:
  • 322 Answers
You might need to open the fridge and remove the frosting from the cooling coil, but you shouldn't do it without reading the user manual first to make sure you don't do something wrong:
Samsung RS21 manual
Posted on Dec 07, 2014
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
Very common issue on samsung rs21 models ,
repair kits have been available for a few years now
this video may help
how to dismantle samsung rs21
Posted on Aug 17, 2014
So how did you solve this AGRCooper?
Posted on Apr 26, 2010
When mine does this, the cooling coil in the fridge is clogged with ice. There is a motor next to the coil which gets iced up and makes a noise.
Posted on Jan 16, 2009
The water dispenser in our GE side by side fridge model gss25wsti made a loud grinding noise and stopped working Has anyone experienced this or have any suggestions
First the water dispenser will not make any grinding noise while dispensing water perhaps a hum. The grinding noise is from the auger motor which dispenses crushed ice ad ice cubes. So please check the intake valve at the rear of the fridge if its working, if not you may have to replace the intake valve. Or if that"s ok please check the control module on the door of the freezer.
Jan 13, 2014 | Refrigerators
Samsung refrigerator problems
Well you will have to trace out the water line and see where leak is coming from .If you disconnect everything and pull on that water hose it would come out BUT do it slowly
Dec 22, 2017 | Samsung Refrigerators
Water dispenser and ice maker are not working, water supply to refrigerator is ok.
Check / replace the filter. Many fridges have a filter readily accessible from the fresh food compartment. The filter should be changed at regular intervals for best performance. A filter that is never changed will reduce and eventually stop water flow through it.
Check the temperature of the fresh food compartment near the filter. It may be "flirting" with the 32 degree mark. If it is this low, water has turned to ice - and will stop water from flowing. Bump the temperature up a tad to see if it solves the problem.
Lastly, the water supply solenoid may have failed. You didn't provide the model fridge - so I can't give specific info about it - but many fridges have one or two solenoids at the rear of the fridge for water supply and ice makers. You should hear a clicking sound from the rear of the fridge on many models when dispensing water or when the ice maker cycles on. If one has failed, you may expect to pay about $15 to $50 for a replacement - depending model.
Typical GE Refrigerator Single Solenoid Water Inlet Valve "WR57X10033"
Solenoid valve replacement is pretty straight forward. Usually all the is needed are some simple hand tools and a rag to pick up spilled water. Make sure the water supply is shut off and unplug the fridge before attempting.
If my answer was helpful - please rate it. Thanks & good luck!
Oct 05, 2011 | GE Refrigerators
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
Water pressure is at a trickle in door dispenser on fridge. filter is clean and mounted properly.
Check the water reservoir in the rear of the fresh food compartment. It may be frozen. If so, there may be an issue with the "damper control assembly" (located in the upper left side of the fresh food compartment) that allows cold air from the freezer compartment into the fresh food compartment. This cold air works its way down to the reservoir (and perhaps other items) and freezes the water inside the reservoir, which disallows regular flow of water at your external dispenser.
Contact an appliance service company.
Feb 19, 2010 | Frigidaire FRS26H5AS Side by Side...
My samsung rs21dgrs is making very loud noise
Sounds like your Samsung RS21 has devoloped a known fault.
Your frdige will be cold in the drawers but not cold above this? Also there is ice around the pipe behind the drawers. it is the ice hitting the fan that is the noise and eventually stops the fan which pushes the cold air around the frdige.Samsung have extended their warranty to 5 years to cover for this.
You need to call the Samsung customer care team 0845 7267864 and should be repaired free of charge. - mine was. When you call, you need the full model number and serial number. my serial number was on the outside left hand side of the fridge. The engineer comes out within a day or 2.
Jun 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
NO WATER COMING OUT FROM WATER DISPENSER
This could be a bad water valve for dispenser on back of fridge or poor connection in the dispenser control. If you could get me the model number I will be able to help you better. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
RS21DGRS SAMSUNG SIDE BY SIDE REFRIDGERATOR
hi thanks for the question it might be a problem with a little frost on the freezer wall fridge not defrosting check the freezer wall with your hand,will feel some frost if this is the problem thanks the appliance doc you
Sep 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Refrigerators Logo
411 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
