Question about E-Machines eMachines Desktop PC
Reconnecting power swith, LED light for power and hard drives on emachine
I saw your response to another question so I thought you might know. I recently had no power on my eMachine T2893. I discovered from the net that they have a notorious problem with supply, and I inspected mine and found a tiny capacitor rolling around inside the supply with brown burn residue where it should have been plugged. I bought and installed a suitable replacement but when troubleshooting before; I removed the connector for the on/off switch and LED lights for the power and HD. The new supply shows a green light on the motherboard but there is no response when I press the on/off switch. I'm thinking that I did not reconnect the the three connectors properly and before searching for a schematic or using a voltmeter I thought you might know. The mobo has a "front panel series of 7 pins. Logic dictates that one rail is hot and the other is common, but that is not the way I remember they were configured when I pulled them. Any help?
  • Anonymous Jan 28, 2009
    i have a emachine t2882 i need to know how the power supply hooks up to each drive and the motherboard
  • E-Machines Master
  • 3,051 Answers
Yes that is true if you look at your wires ahnd you will see that one says hdd and one says spkr and so on now look closley at the board and you will see the same thing on the moboard if you are not abloe to read it you should be able to go to the manufacture of the board and there is a section for online manuals that u can download ok i hope this helps out a little bit please keep me posted ok this i can help you out morte if you need ok best reggards mike
Posted on Sep 06, 2008
MB schematic for HP Pavillion 7960 desktop pc
it is wrote on the mother board... look in the front left hand cornor,youll see a bank of 8 sets of 2 pin conectors..the abriviations are...pw=powe swith..rs= reset ....pw led = front powere light...hdd led = hard drive led
Mar 12, 2012 | HP Pavilion 7960 PC Desktop
EMachine 2862 Desktop Dead On Power-Up
check all the leads to the hard drive and check that the fan starts spinning when you switch it on if it dont start then the problem is the switch these do often go and can be easily replaced and they are not expensive i had the same problem and found that it was just the switch hope this solves your problem for you you can bypass the swith so that the computer comes on when you turn the plug on but when you shut down the computer this shuts everything down but the switches are cheap enough to buy if you have changed the power pack then the only thing it can be is switch .................................
Oct 31, 2007 | E-Machines T2682 (000002965) PC Desktop
Emachines e4026 non-responsive
I don't think it's an overheating CPU. It would stay on for a bit longer if it was that. My best guess is a power supply issue. Either your power supply is bad, or more likely something is pulling too much power from it. Emachines are notorious for using the bare minimum hardware... possibly the extra hard drive is pulling more juice than the power supply can handle, so it shuts down. Try disconnecting power to the new hard drive and see if the machine comes up. If it does, you need a new, higher wattage power supply.
Sep 06, 2007 | E-Machines eMachines Desktop PC
HDD led flashes non-stop after case swap (emachine et1331g-03w)
it will be next to ur power led or u will find hdd led wrritten on the motherboard
Jun 04, 2010 | E-Machines eMachines Desktop PC
Had to replace power switch on emachine computer need to know where wires go
You must check cable(small) one the (left or right) one hard drive, CD Drive, floppy disk and for motherboard (the big one) .You check the manuals, is not hard just follow where the power lines.
Feb 21, 2010 | E-Machines eMachines T3830 PC Desktop
I DONT KNOW WHERE Tto pug in the power
Power Led?
hard drive Led wires?
If you are building a machine these areusually pluged directly into the motherboard.
the plugs are usually only compatible to their special sockets on the board. all you need to do is to examine the plug ends and look for sockets withsimilar shape and size as the plug.
Jan 05, 2010 | E-Machines eMachines Desktop PC
I have a eMachines T2082 Inc. L7VMM2 Main bdBoard: KM266-8235 Bus Clock: 133 megahertz BIOS: Phoenix Technologies, LTD 6.00 PG 02/23/2003 The Hard drive access led got disconnected, do you know what pins...
This is the support page for the board. Scroll to bottom of page and download the manual which contains the location of the hard disk LED pins. Thanks Mike
Nov 29, 2009 | E-Machines eMachines Desktop PC
Cant boot my emachine 2984
Did you check the CMOS battery and the CPU fan. Those are two things that if aren't working the way they should be, then some computers will not boot up. Try this first then post a response if you still can't get it working.
Sep 01, 2009 | E-Machines eMachines Refurbished EMA...
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Reconnecting your emachine power
i had the same problem so i just bought a new computer not to even try to waste any money on my e machine due to the fact that is was 5 years old
Sep 05, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
129 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
