Question about GE Slim Spacemaker 7-5295 CD Shelf System
Alarm setting?? I have a Spacemaker 7-5295 There is no alarm on this model,unit is about 1 yr? old. Just started setting off an alarm at 11:59pm every evening.Have to push OFF button to stop. Cannot find any setting for this . Any Idea's?? Thanks in advance Russ
  • 1 more comment
  • Anonymous Oct 19, 2008
    I have a Spacemaker 7-5295 also
    I can not find any alarm setting on this model. Not on unit or in operators manual.
    Just started setting off an alarm at 11:59pm every evening. Have to push OFF button to stop.
    Has anyone found a solution??
    Thanks
    D
    There are no alarm setting on unit or in the operators manual.
    Has anyone found an answer?
    Thanks
    D
    OK
    Figured it out. I was able to recreate alarm by setting clock to 1159pm and at 1200am, alarm wen off. I removed the backup batteries, unplugged for about 5 min. Plugged in and reset clock and installed batteries. Tried to recreate again and alarm did not go off.
    Try it
    D
Oh my god, I have had this problem for so long and had lost the manual. It was driving me so crazy....every night at 11:59!! I finally plugged it into a timer that turns the machine off at 11:55, then turns it back on in the early morning. I will try your method. I really hope it works! J
Posted on Sep 17, 2010
How to set the time on the clock
Posted on Aug 11, 2008
    Novelist:
    Champion:
  • 277 Answers
Try "playing" with the CountdownTimer feature: Setting the CountdownTimer 1. Press TIMER ON/OFF to enter timer setting mode. The red TIMER icon will flash on the display. 2. To select countdown time, use the TRK (SEARCH?TUNE) / buttons to select the correct time. Press and hold to fast forward or fast reverse countdown time. 3. Press TIMER ON/OFF again to activate the timer. The unit will beep twice to indicate countdown has started. The red TIMER icon will remain lit during countdown. 4. Press TIMER ON/OFF to turn timer off at any time or after it has sounded. good luck
Posted on Nov 06, 2005
SOURCE:
How do I set the alarm on this model, which I cannot find any where. Grateful & puzzled. Model 7-4806A GE Clock Radio
if I could see a good picture of it perhaps I could assist . most have a slide bar to turn the alarm on then you use the hour or minute buttons to set .
Mar 18, 2016 | Audio Players & Recorders
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
Oct 29, 2011 | Emerson Smartset Clock Radio
How do I turn off the alarm clock
Hello
The unit has 2 alarms (alarm 1 and 2). They can be used
together or independently. Alarms 1 and 2 have different
sounds so that you can differentiate them. The alarm will
sound for 1 minute unless it is disabled.
To set the alarm:
Navigate to "Set Alarm" setting mode as shown in the
Changing Settings section. The order of the settings is;
alarm 1 or 2, hour and minute.
To enable or disable the alarm:
• Press MENU until you reach alarm 1 or 2 display.
• Press [UP] or [DOWN] button to enable or disable the
alarm. "-:--" means disabled.
OK.
Sep 14, 2011 | Oregon Scientific WR108 Weather Radio
I don't know how to set the clock for a MA4203 model
I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
  1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
  2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
  3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
Feb 05, 2011 | Memorex Audio Players & Recorders
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
Dec 22, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
I have an Adimax watch and can't set and activate the alarm
Thanks for the answer - I have a Adimax watch which was given to me NOTa Bulova brand - I have not fixed it but I can't afford to pay for your advice as I am a 76 yr old pensioner. Thanks for your prompt reply anyhow.
Kind regards,
PJP
Sep 22, 2009 | Bulova Watch
HOW DO I SET THE TIME?
Wildbill,
My wife has the AudioPhase SPR1 AM/FM 2 AAA portable sports type music player. There is no pdf manual available on internet yet - I will scan and post when I get time. The paper manual says:
To set the Clock:
1. Turn unit off.
2. Press MEMORY once: the clock will start flashing.
3. Press DOWN/MIN to set the minutes, press UP/HOUR to set hour.
4. Press MEMORY again to complete time set.
5. There is always an AM/PM indicator on the LCD display to indicate DAY or NIGHTTIME or night.
To Set Alarm:
1. Turn unit off
2. Press ALARM once: the alarm will start flashing.
4. When alarm time setting is complete press MEMORY 3 times.
5. The alarm setting is completed.
6. Now alarm standby is ON. ALARM indicator will now show on the display.
--> Alarm will only make a noise throught the headphones. When it goes off cancel it by pressing ALARM.
Canceling ALARM standy by.
1. Turn unit off.
2. Press ALARM twice.
3. Now ALARM standby is off.
Radio:
To Seek press UP/HOUR or DOWN/MIN to click throught the frequency or press and hold to seek.
Oct 27, 2007 | Griffin Technology SPR1 AM/FM Radio
GE Slim Spacemaker 7-5295 CD Shelf System Logo
331 people viewed this question
Top GE Audio Players & Recorders Experts
Racki123
Level 1 Expert
john1959ny
john1959ny
Rob Hill
Rob Hill
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
