Question about Motorola Mobility RAZR V3i Cellular Phone
Scree went black
You say fix flex - how does one go about doing that?
Please advise.
Thank you.
  • 3 Answers
this site rocks
this is a link to a file that would show you how to fix flex it. you have to download it, but it works...
Posted on Sep 12, 2008
When sliding screen open stuck on blank white scree. Can receive call and phone still making sounds but no data on screen. By reading the reviews not an uncommon issue. How to fix? Has been white since...
Hello,that is a flex problem, all you need to do is just to get a new flex from a mobile phone accessories store to replace the faulty one.if that is done,your mobile phone will function a supposed.
good luck,
take care.
Dec 02, 2010 | Cell Phones
The display scree is flickering. I have removed the battery and refixed it but the problem persits
Please connect an external monitor. If the screen still flickers then it is your video graphic adapter is the problem, on the other hand, if it does not occur then its your LCD hardware which can be the LCD itself and hopefully its just the flex cable that connects to your notebook. Please let me know of the outcome and maybe there would be a need to assist you further. Thank you and regards.
Aug 30, 2010 | Computers & Internet
We have black bars going down the middle and one side of the scree. We have seen many video's on soldering the pieces but this tv seems different then most. HELP economy has us and can;t afford a new one.
Black bars down the middle of the screen and on one side that affect the MENU and the picture, are caused by the panel or Drive board. This is generally not repairable. The panel flex cables are sonic welded, not soldered. A plasma Panel is very dangerous to operate with the back off. Be careful!
The drivers for the panel are often attached direct to the flex cables.
Apr 16, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Inside screen when black and the outside sreen was still working then it went black my phone still works like normal just the screens are black and i cant see anything
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Apr 16, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
My screen went black.The phone works but its Black
Were the problem of your phone is from the flex that connect the panel to the screen its aether it has curt off or it has move away from it position.
What need to do is to unscrew your phone with phone screw the fix up the flex your self .
But if you cant take of this, take it to a good phone work shop around you to fix it up for you then you will be able to make use of phone again.
Thank for using fixya .
Mar 17, 2010 | Motorola Mobility Rival A455 Cell Phone
White screen
The flex wire connecting LCd with camcorder is a problem. Mine was the same then after went black and all touch functions were ok.I changed it by miself it's cheaper, and it's like new DCR-SR32. The wire I got from the repair shop. The nubers are on the flex wire.Good luck
Hope it helped
Sep 18, 2009 | Sony DCR-PC55 Mini DV Digital Camcorder
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
Black Laser Drum
I just end of ordering it and it should be here first thing this morning. Thank you.
Mar 19, 2009 | OKI C5500n Printer
Black Cartridge will not print.
Flex ribbon cable at the rear of the housing that the balck cartidge fits into is probably punctured. It happens a lot with this model. Remove the black cartridge and look at the electronic ribbon in the rear where it contacts with the cartridge contacts. There is a spring tension wire in the housing that holds the cartridge snug that breaks loose and punctures the flex ribbon rendering the printer useless as there are no part available to repair this HP defect. It is a well known defect / poor design flaw in this machine.
Jul 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Motorola RAZR
ya'll sould go to ur near cellphone service to replace the flex cable because is broke
Apr 20, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
