This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
If the ports where the oil comes out aren't clogged, you will have to order a oil pump and then take apart the saw from right underneath the bar. The oil pump is run by a worm gear that strips easily.
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
Hi there, a couple of features come to mind that may be the cause of your problem.
Firstly, make sure that the saw is unplugged from the power supply.
The chain brake is active and wont allow sprocket movement and hence the chain. If necessary, pull the front guard (in front of the front handle) back until it clicks.
Electric saws generally have an additional motor-stop feature built into the trigger mechanism which is deactivated when the trigger is squeezed. So, in order to move the chain along the bar the trigger needs to be squeezed releasing the motor-stop. A tip - wear gloves when handling chains and move the chain towards the bar tip ie in the direction of the cutters - if the chain suddenly stops you wont remove several layers of skin in the process ! better still use a screwdriver against the back of one of the cutters and move it forwards - there should be some resistance and there should be no slack chain on the underside of the bar. Hope this helps.
are they two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Does the chain move when the motor is started? Make sure the chain doesn't droop from the lower side of the bar and the teeth cut toward you on the bottom side. The chain should not be so tight that you can't move it by hand. Run the saw for a few moments with the tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Make sure that the chain is properly sharpened and cuts without undue effort. Hope this helps!
