Brother DCP-585cw All-in-One Wireless Color Inkjet Printer Logo
Posted on Aug 14, 2011
Printer will not comnnect to the network wireless model brother dcp-585cw
SIMON MATTHIAS NG
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 58 Answers
  • Posted on Sep 21, 2011
SIMON MATTHIAS NG
Contributor
Level 1:
New Friend:
Cheetah:
Answers
58
Questions
0
Helped
24006
Points
75
People usually think connecting a printer via wireless is as simple as connecting a PC. However it is not the case. A printer need to communicate with every PC in the same internal network, however each PC will not communicate with other PCs in the same network to protect it private files and also the firewall settings. Next every PC is set to get a dynamic new IP address from the DHCP server everytime when it is powered up and plug into the network. But the printer need to get the same fixed IP address when it is powered up in the LAN.
So the Printer in a LAN need to set up a fixed IP address such that everytime when it is powered up, it has the same IP address that each PC could still get communicate with this Printer. Apart from setting this in the Printer, you also need to reserve this Fixed IP address with your Printer's MAC address in your DHCP server of the router. Otherwise it will get conflict with other PC or device that could have assigned the same fixed IP address. Then you have to setup your Firewall of your PC to let communication to this Printer. Else it will be blocked.
Lastly make sure you install the printer driver correctly in your PC with the same Win OS version such that it could detect the fixed IP address of your printer. Then it should work correctly.
Please let us know any problem you may have in future.
I took my printer home from my workplace and i want to use it at home it is telling me it is offline it is adcp 585cw wireless
You have to check whether your printer was set up as a network printer or just a one to one printer in your workplace.
If it is a network printer, please check with your IT administrator whether it was set up with a fixed IP or using dynamic IP. After get these details, just set it up same as in your home network.
I am trying to re-install my brother printer DCP-585CW but it says driver out of date so will not install sortware
There may be a issue here that you have not unistall the original program before attempting to reinstall the new program.
If you have done this and still get a problem, you should go direct to Brother's web site to download the latest driver version that corresponds to your Windows OS such as XP, Visita, or Win 7.
2answers
Brother DCP 585CW unable to print error 46
A possible reset might solve hence remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
How do i load A4 photo paper in my DCP-585Cw Printer
Visit this link to download user guide for DSC-585CW and see page-13, it is about how to load the photo paper.
I hope this will solve your problem,
Good luck and have a nice day
Rating the solution is highly appreciated.
Mydcp 585cw is not printing with the black i have changed the ink cartridge
did black ink detect with the ink level status? run print head clean in printer preferences tool maintenance.
My brother DCP-585cw printer prints too slow. What can I do to speed it up?
Go to the control panel and then into the printers section. Right click the DCp-585cw and select printing preferences. Under the section quality chose fast. This should speed things up.
Norman Weimar
Norman Weimar
k24674
