Question about Panasonic PT-56TW53 56" Rear Projection Television
Pt 56tw53 picture trouble
Television went off by itself. power but keeps flashing. i unplugged the set for about 1 hour. it turned on but the picture was very bright with washed out colors. there are severl swirly lines on the screen in red green and i belive blue. i unplugged the tv again for several hours and the same thing was found when i turned it back on. this time however, after being on for 1 hour it shut itself off and now the power button is blinking again. the set is 2 years and 6 months old. i live in the new orleans area. so if you know of anyone or if anyone know how i might be able to fix the problem..........i would greatly appreciate it. tv is out of warranty. thanks carolyn
  • 1 more comment
  • LLS222 Nov 19, 2007
    Television just shut off, however, the power button keeps flashing. I tried to turn it back on but the tv comes on for a second and then shuts back off.
  • dfab Feb 02, 2008
    same problem
  • darrylmarc Mar 26, 2008
    I have the same problem, tv will not power up.
    Flashing red light (3 flashes and then long delay).
    Novelist:
    Champion:
  • 277 Answers
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Posted on Nov 06, 2005
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Based upon your description, the problem area is the convergence circuit. These sets usually have a couple of large black ICs that control the convergence. These Ics either have bad connections on the pins or are failing. You can try resoldering the pins of these ICs if you can solder, or replace them. These ICs are usually marked STKxxx and are attached to a heatsink.
If you get this repaired, expect to pay about $30-$40 for each IC (there can be 2) along with the local labor rate for projection sets.
Dan
Mar 26, 2008 | Panasonic PT-56TW53 56" Rear Projection...
The power light is flashing and the set will not turn on.
Possible fault in the power supply section of the Tv, the SMPS, it might be cutting off due to a current limiting function in the circuit. make sure that the connectors are tight specially the ground to the power supply. The other fault can be the lamp itself as it can be defective. make sure that the connections to the lamps are tight. A cross check onthe voltage of the circuit+B can be useful to determine the missing problem.
Nov 05, 2010 | Panasonic PT-56TW53 56" Rear Projection...
I have a Samsung 50" HDTV DLP TV that I purchased 10/12/2008. I turned the set on the other day and it would come on generate a normal picture then power itself off. I unplugged the set for a few hours...
Lamp could still be going out they only last for 5,000 hrs some 8,000 playing hours.
Check the Lamp Fan if it stops running when Lamp turns on set will turn OFF.
But if you have never replaced Lamp Problem will be the Lamp Mats Has them for $99.00
1-800-628-1118
Oct 23, 2010 | Samsung SP50L3HX 50" DLP TV
My panasonic t.v. turns on but has a black screen
How many times does the light blink? Thats a error code indicating what the problem is.
Apr 15, 2010 | Panasonic PT-56TW53 56" Rear Projection...
When I turn my TV on it shuts back off and power light flashes
Power supply board is dead.Replaced the power supply board well get ur power back and solved this.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 10, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Panasonic PT-56TW53 56 in. Rear Projection Television- won't turn on -flashes 3 red lights- what's up? Turns on for a second, then it turns off and red light flashes 3 times... I've seen several other...
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part numberAA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Feb 16, 2018 | Panasonic PT-56TW53 56" Rear Projection...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
No Audio or Video, blinking power light
Did you ever find anything out about this? I have a pt-53tw53g with the exact same problem, and I've been unable to find out what the three flashes means.
Aug 02, 2006 | Panasonic PT-56TW53 56" Rear Projection...
Panasonic PT-56TW53 56" Rear Projection Television Logo
130 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
