Question about Lexmark Z645 InkJet Photo Printer
Printer and computer wouldn't communicate
Help!
    Scholar:
  • 191 Answers
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice.
Posted on Sep 05, 2008
  • Moses Clive
    Moses Clive Sep 05, 2008
    1. When all the files are copied, click Finish.
    2. Turn on your printer. Windows should detect the printer's presence
      and finish the installation. If the option to print a test page is
      offered, do so. This will confirm the installation. Click Finish.
  • Moses Clive
    1. In Windows XP default view, from the Start
      menu, select Printers and Faxes, and then double-click
      Add Printer. In Windows XP Classic view, or in Windows
      2000
      , from the Start menu, select Settings,
      then Printers, and then double-click Add
      Printer
      This will start the Add Printer Wizard. Click Next.
    2. Select Local printer or Local printer attached to
      this computer
      . Click Next.
    3. Select the LPT port.
    4. Select the manufacturer and model for the printer you are
      installing. If you would rather use the driver disk that came with the
      printer, insert that disk and click Have Disk, and then
      browse to the driver disk and the proper folder. Click Open,
      then OK.
      Sometimes at this point, you will be asked if you print from
      MS-DOS programs. Most people can safely answer No
      here, but if you print from any DOS-based programs, answer
      Yes.
    5. Windows will offer a name for the printer that you may change if
      you like. If this is your only printer, or you wish to use this printer
      most of the time, select Yes to make this the
      default printer.
    6. You will be given the option to share this printer on the
      network. Unless you specifically want to do this, select Do not share
      this printer
      . Click Next.
    7. Make sure the printer is connected and turned on, and then answer
      Yes to print a test page. This will ensure that your printer
      is working. After the page has printed, click Finish. Your
      printer should be ready to use.
Printer cable connect the computer but printer said to communication problem,solution pls
your computer have not printer driver if have reinstal it and try with different usb port
May 18, 2012 | Canon LASER SHOT LBP-2900 Printer
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
Printer S405 will not communicate with computer, USB has been checked and the printer has been uninstalled and re-installed about 5 times now - help!
How is the printer connected to your computer? Wireless or hardwired with a USB cable? This could be caused by some blocked printer communication processes in the firewall, signal quality problem, etc. Here are some articles about communication problems and the troubleshooting steps to determine and help fix the problem at http://bit.ly/jD8fSJ.
May 12, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark x4975 printer not communicating with computer
This article from the Lexmark website on No Communications Error When Trying to Print or Scan might help resolve the problem. Or simply unplugging and replugging your printer into your computer and into the power source can help fix minor communication issues.
Feb 21, 2011 | Lexmark X4975 Wireless Color Multifunction...
Printer cannot communicate with the computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Sep 10, 2008 | Lexmark Z735 InkJet Printer
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
My printer has a problem communicating with my windows Vista computer
Please check to make sure your cables are all plugged in all the way. If one of the cables is loose (power or data (at either your computer or your printer)) it could be causing this problem.
Apr 24, 2008 | Lexmark Z640 InkJet Printer
Computer and printer not communicating
unstall it all download drivers from website not use cd ok
Feb 10, 2008 | Lexmark X2500 All-In-One Printer
Lexmark Z645 InkJet Photo Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
