Question about Refrigerators
I have a subzero 501r (refrigerator only no freezer) i am having ice build up on the back. i had a repair man come out yesturday and he said that i needed more freeon? the low psi was 5. so i paid him 200 to add it. before he left he scrached his head and now the low psi is 17 and the high is 200? i still have ice on the back of the frig.
  • 1 more comment
  • llazzaro Oct 01, 2008
    We have the same problem. I did notice with ours, the compressor runs constantly. A rebuilt compressor was just put in 2 years ago (by previous owner). I have found 2 possible fixes but haven't yet tried either. One is a new thermostat and the other is a new condenser fan blade. Evidently, sub zero came out with a new condenser fan blade due to the problems we're describing; however, I've not yet confirmed this information. The fan blade is only about $9 and the thermostat is approx $60. I plan to try the fan blade first and will post if it fixes the problem.
  • gauden Oct 14, 2008
    i have a same problem and called a sub zero tech to check he said i need to replace the condenser and the thermostat for $1,500.00.
  • Anonymous Nov 27, 2008
    My condensor runs all the time too. We haven't pulled out the refrigerator to see if ice is on the condensors.  Does anyone know the energy use of these 501R sub zero refrigerators.  I have a huge electrical bill.
Rotu
  • 175 Answers
SOURCE: Sub-Zero 550 with Bottom Freezer
The life expectancy of these is as long as you want to fix em. I stll work on plenty of them builty before 1980. You may have to pay $900 for a bad compressor, but the fridge replacment cost is around $600, so it's up to you. take the back wall off behind the shelves an look at the coils. If the coils are frosty on only part of the coils (less than 2/3 I would say) Then you have a freon leak. likely from the evaporater (this will need to be cut out and soldered in with aq torch) If you have all frost top to bottom, defrost it, turn down the setting, and check that your door seals well and the door doesnt bounce open when you swing it shut. If there is no frost at all, feel the frame around the door opening. If its warm, take of the upper grille and then the upper sheild on the left side (2 screws). Use a flashlight to shine trough the condenser (thing on the right, looks luike a radiator) if you shine a light throuhgh towards the fan, but cannot see the light come through on the fan side, you need to vacuum off the condenser and try again. If light still does not get through, go to your local auto parts store and buy 2 cans of NON FLAMMABLE brake cleaner. Unplug the unit and hose the condenser down with the stuff untuill you can see light through it from the flashlight. this will be messy, so have a spare rol of paper towels handy. The fumes will be bad too so open a window and put a fan in if you can. If the frame of the fridge is not warm, and there is no frst, discannect the cold controll and use a piece of wire to connect the two wires together after you disconnect them from the cold control. Do not connect the green wire, and be carefull as ther will be 110volts in one of those 2 wires if you didnt unplug the fridge. let the thing run with the control bypassed for 15 minute or so and watch the coils to see if they frost. If they frost all the way, top to bottom, replace the cold control (one for the fridge on the right, by the way)Hope you can get the info you need out of this. Good Luck!
Posted on Sep 07, 2007
SOURCE: subzero 532 ice buildup in frig
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Posted on Aug 19, 2008
SOURCE: Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Posted on Sep 15, 2008
  • 102 Answers
SOURCE: Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Posted on Aug 05, 2009
  • 109 Answers
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Posted on Oct 22, 2009
Subzero freezer not freezing
this subzero freezer compartment did not free, but stayed cool. The problem was that defrost limit switch went bad, so when it was going to defrost cycle heater never came on, so it builded up snow and ice on evaporator coils and air stopped circulate. I replaced that little thermostat, and melted down ice.
Jul 11, 2014 | Sub-Zero Bottom Freezer Refrigerator
Frost on back wall of SubZero Model 501R. have cleaned coils
You've got a freon leak. Most likely the evaporator coil needs to be changed out. They upgraded the part number. Instead of copper, it's made of aluminum now.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero Refrigerators
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
Aug 11, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice forming in refrigerator
Sounds like the defrost system is not functioning properly. There are a lot of possibilities -- probably ought to call service unless you have significant experience with appliance repair.
May 08, 2009 | Refrigerators
SubZero fridge problems
Ice buildup on the back left wall is the sign of an evaporator leak. Not something you can fix yourself, at some point it is going to be completely out of gas, I would call for service now
Apr 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Feb 03, 2009 | Sub-Zero 561 / F
Refrigerators Logo
1,310 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
