Without seeing plates it is hard call. personally I would remove old plate and install new plate in accordance with instructions. You want to not void warranty by using old plate. There should screws into the studs this is the desired mounting. You can use your knuckle and tap across the wall, when you reach stud the sound will be different. Good Luck
when I replaced MW units for customers I always used supplied parts. I have also been called to correct installation by store. the people they sent should not been allowed to attempt the project ( I didn't mind as i charged for my time and tools and knowledge.)
Almost all over the range micros are 30 inches wide. They did make a few 36 inch models but most are 30. Top to bottom back measurement can be between 16 to 18 inches. Most makes are similar in size. Back wall mounting plate will have to be exchanged since each company has a slightly different design but the wall plate comes with the new unit along with mounting hardware.
From what I can see online, the microwave is attached to the wall via a mounting plate, so if you lifted the microwave up and out at least the top if not all of the microwave should be released from the mounting plate.
There should be two or three bolts inside of the cabinet above the microwave. Remove all bolts and then pull top edge of microwave forward (away from wall). It pivots on a mounting plate which is secured on the wall. Pivot forward and lift microwave up a little bit off of the ledge of the rear mounting plate.
Make sure to feed the electric wire (plug) through the hole in the cabinet as you pivot and remove the microwave. Sometimes cooking grease will make the microwave stick to the cabinet. So after removing the bolts use gentle force when pulling on the microwave. I hope this helps and good Luck!
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
you can not get a plate . only plate that mounts it is the one that came with it . now I did this with my own sharp and this wil work with any . cut the wall benind same size of micro / this will let you slide it into the wall almost 3 in . giving you more room to cook and work on range top. she loved this . then attach the front by the bolts from the top or screw/s to the side of both .. makes a neet install ..****/ feed back pls .. dont forget the power goes in the top ,,
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
