Question about LG DR-4912 DVD Recorder
Will not initalise DVD +RW
Hi guys. MY DVD player will no longer initialize DVD +RW discs. When inserted the player says initializing, time remaining 2:40. it seems to start the procedure, then quickly finishes, then starts again at the beginning. Once it starts this cycle you cant stop it! Have tried lots of different makes of DVD but all exhibit the same problem. All other DVD formats are fine. Any ideas?????
Cliff
The spindle may need cleaning. if the spindle is dirty the disc will slip causing errors when burning discs.
to do this you will have to open the unit up and remove the drive from the machine.
undo the screws holding the casing together (7 In total) and remove the top of the unit
the drive is similar to a normal pc dvd drive and is held in a clamp
next undo the four screws holding the circuit board to the right of the drive and carefully move it to expose two of the four screws holding the clamp in place, the other two screws are already visible on the left hand side of the drive
now carefuly remove the two cables from the back of the drive and undo the four screws holding the clamp in place. you should now be able to lift the drive, still in its clamp, from the unit.
undo the four screws holding the drive in the clamp and slide the drive out
on the bottom of the drive there are four screws holding the casing together, remove these, and carefuly coax and tease the casing apart. dont use force, be gentle.
using a cotton bud and alcohol, carefuly clean the spindle, removing all dust and dirt. you may as well clean the lens and any other dirt from the unit whilst you have it open
put the machine back together by reversing these instructions
Posted on Feb 26, 2009
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
Initialising and finalising dvd -rw disc
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Mar 30, 2015 | Televison & Video
Disc says loading and goes no further
First try different DVD discs. All players of DVD or CD are likely to fail in this way over time. You can try to clean the lens inside the unit, but it may not fix it. Its wise to buy the cheapest replacement, because they never last much longer than a year.
Dec 15, 2013 | Initial 5820 Portable DVD Player with...
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
When I insert a new DVD RW it says can not read disc check disc. The camera will not give me the option to initialize disc either. These are brand new discs that I am using. I can record with older disc...
You have to be sure you bought the correct disks. Look in your manual or your camera. You could use DVD-RW or DVD+RW. They are not universal. You have to use the correct version. You also may want to try a DVD-R or DVD+R. They are cheaper but are not re-recordable. They are not erasable either. A good thing if you don't want to "accidentally" erase your movies!
Dec 18, 2009 | Canon DC210 DVD Camcorder
My Initial DVD player does not recognize discs at all
replace the optic lens and the spindle motor or if you do not have time try to purchase a optic assembly so that its easily to replaced.you have to purchase is the same model as your unit brand.
Sep 24, 2009 | Televison & Video
Can't get the Initial Settings screen
Hi,try this...with the dvd tray open,hold the rec button and play button on the dvd for 5seconds.hope this helps?
Mar 25, 2009 | Panasonic DVD-A110 DVD Player
Cannot initialize disc Canon Dvd camcorder dc210 (dvd-rw)
plz try to clean the DVD rom lens with a lens cleaner..
Feb 07, 2009 | Canon DC210 DVD Camcorder
LG DR-4912 DVD Recorder Logo
221 people viewed this question
Computer Repairing
Computer Repairing
