Panasonic PT-47WX49 47 in. Rear Projection Television
Problem for Panasonic PT-47WX49 47 in. Rear Projection Television
Distorted Color and geometry of Picture
By SteveLC on Nov 03, 2005
I have a PT-47WX49 rear projection Panasonic TV that is 4.5 years old. When I powered it up yesterday, the picture came on with a nonuniform distorted appearance. In general, the picture appears to be misaligned with a blue shadow on the entire picture. In addition, there is a blue semicircular area at the bottom of the picture with a red semicircular shadow above the blue area. It is impossible to align the blue and red using the convergence functions as different parts of the picture are out of alignment in differing amounts. Finally the geometry of the picture appears to be distorted in the blue and red semi-circular areas at the bottom of the picture.
Clarification Request
Posted by kevinreining on Oct 26, 2009
Picture is distorted and only filling up a portion of the screen. It is a magnavox model 7P6033W102. Please help
Same Problem
Apr 04, 2009
-   I have a similar issue with a Magnavox 60P8241 60". It appears to have a focus problem. is there something that can be done without changing out a whole board? -   rbailey
Feb 06, 2009
-   jfjjfuiopvg-   budmftud
Sep 08, 2008
-   Same problem, the conversion did not work. Not only do I still have this blue wave at the bottom of my screen, like 3D but now all the colors are off. I cannot line up the x's on the conversion screen. It is worse now-   Guest
May 31, 2008
-   pt-51hx41ce - multiple image. try to replce stk392-110 convergence amps. Not able to take it out. How to replace. Could you please advise.-   sidhu123
Apr 20, 2008
-   distorted picture on outside edges of screen. Pink stripe on rightside outer edge. have reset convergence and problem stays the same-   dj5432
Best Solution
posted on May 12, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just replace the convergence ICs.
Solution #2
posted on Sep 24, 2007
Helpful)
Terryfic
Rank: Guru  Panasonic Expert
Rating: 87%, 1707 votes
Replace convergence Ic's,then check alignment.
Check power supply
pico fuses.DCU rarely at fault.
Was this helpful?
Yes
No
Solution #3
posted on Jun 22, 2006
Helpful)
hardrocko
Rank: Guru
Rating: 85%, 922 votes
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #4
posted on Nov 04, 2007
Somewhat Helpful)
cycus
Rank: Wiz
Rating: 84%, 213 votes
change the stk ic
Was this helpful?
Yes
No
Solution #5
posted on May 14, 2008
Somewhat Helpful)
mikaspt
Rank: Apprentice
Rating: 75%, 1 votes
replace the 2 STK392-110 big IC with a metal cooler.
Was this helpful?
Yes
No
Solution #6
posted on Jan 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i had the same problem replace convergence board is the way to go, Samsung 165cm rear projection.
Popular Solutions for Panasonic PT-47WX49 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX49 47 in.
Do you recommend Panasonic PT-47WX49 47 in. Rear Projection Television?
Answer
Answer
hello - the tv power turns on but 5 seconds later the power shuts off and will not turn back on. If... (More)
Answer
the picture goes off every 15 minutes leaving a blue screen
17 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 31, 2008
I have the same problem with my Sony projection TV. It looks like your wearing 3D glasses. I was told to have someone look at it it was $100 plus if it is the convergence it'll be about another $350. Any ideas on a eay fix? Sony had me try a few things, but it didn't work.
Comment by Guest, posted on Mar 24, 2008
I cannot adjust the lens given in the crosshairs. the lens will move vertically but not horizontally. The picture suddenly went out of focus and I have fixed it before but the lens will not move now, see first sentence.
Comment by sandy5728, posted on Mar 03, 2008
my picture on my tv in red blue in color
Comment by Roygj, posted on Feb 26, 2008
I have the Panasonic rear projection model TX-51P400H and am experiencing very similar problems. The convergence cannot be adjusted successfully with the remote and I still end up with a best result of a reasonable image on the centre of the screen with the three images (red, blue and green) on the perimeters of the screen. A technician friend replaced the brightness capacitor as his past experience on crt tvs indicated that this can effect convergence, but this fix was unsuccessful.
Comment by rlgood, posted on Feb 08, 2008
Same problem. Distorted vertical geometry. So bad you cannot read the menu if you try. Only about 3 years old and put in a brand new replacement lamp just a month ago after a month long warning that the lamp was about out. Cost of the lamp was $225. This will be my last JVC. Model is JVC 52z575. Called the cable guy who had me restart the cable setup to no avail.
Randy in Oklahoma
Comment by alwayzsharon, posted on Jan 04, 2008
when aligning the blue moves fine but the red will not move side to side
Comment by Guest, posted on Dec 11, 2007
I have a phillips\magnavox model# 60p8241 57" in general the picture appears to be misaligned with a blue and red color and the tint seems to be real light. I have adjusted the color just a little but the overall picture is still not clear.
Comment by Guest, posted on Nov 25, 2007
i have a projrction screen with the convergence out of adjustment and the menu does not have a adjustment selection to adjust
Comment by Guest, posted on Nov 22, 2007
HItachi 42 inch, blue hozintal line sags when moving from left to right, distorting entire picture. gives a double image. TV is about 5 years old.
Comment by richmondn, posted on Nov 19, 2007
I bought this 53SBX a few yeas ago, it has the red distortion as yours. Magic focus could not fix it. Can we adjust some button to fix the problem?
And if it is, then where ?
Comment by mfleenor2005, posted on Nov 14, 2007
when i turn on the tv the whole picture is blurry and everything is out of place
Comment by MVBME, posted on Nov 12, 2007
I have the panasonic pt-61sx30cb. In addition to the distorted color and geometry of the picture, it seems the television cannot stop from switching between 4:3 and 16:9. It constantly flickers like it cant choose which format. then it straightens up. It also will stretch the picture when its acting up. example if im reading subtitles they stretch right out of view.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic PT-47WX49 47 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
