Question about Aiwa NSX-A115 Shelf System
Cassette door stuck closed
Unable to open right cassette door. A tape is locked inside. when 'eject' label on cassette door is pushed there is very little movement, unlike the other side, which depresses slightly and opens.
  • Anonymous Mar 13, 2014
    The tape door will not open; nor will the tape play or rewind / wind.
    Novelist:
    Champion:
  • 277 Answers
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Posted on Nov 03, 2005
SOURCE:
How to play cassette
Hi Louise Siegel
By using the a standard Cassette Player
  1. Open the tape compartment door by pressing the eject key, usually far to the right and marked with a raised square.
  2. Insert the cassette, label side up, with the tape edge facing out.
  3. Press and lock down the play key (green with a raised circle / triangle) to start the player.
May 22, 2016 | Audio Players & Recorders
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Vhc tape is stuck in my video cassette recorder, it is a much older vcs, is their any way I could possibly that I can get it out without breaking the vcs?
Take ur finger senses all around the VCR the open flap door for sensors also pushes the eject button too as the same time,when the right sensors it hit ur finger the VHS tape will come out.
Mar 16, 2011 | Zenith Televison & Video
A VHS tape is stuck in my player. How do I get it out?
the tape might have stuck inside.. you need to open it and remove it on your own.. if you think its risky go to any nearby shop of electronics.. they will do it for few bucks..
Jul 10, 2009 | Zenith Televison & Video
Tapes stuck in the cassette and dooes wont eject on both sides
I hate to say this but you may have wrapped the spook around the player inside. I have not had much luck opening jammed doors that result from spooled up tapes.
Richard
May 31, 2009 | Sony Audio Players & Recorders
Rca CC9360 Mini DV Digital Camcorder
Usually this occurs when the door latch release mechanism is broken. This mechanism is located on the basket where you push the tape in and it's job is to open the tape "door" on the cassette that you insert. Unfortunately, the only fix for this is to replace the cassette basket. I know your camcorder is actually made by JVC, but I don't have access to a manual so I can't supply a part number for you.
Nov 07, 2008 | RCA CC9360 Mini DV Digital Camcorder
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Aiwa NSX-A115 Shelf System Logo
692 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
