Question about Magicard Avalon Duo Thermal Card Printer
Getting it ready for printing
Keep trying to set the ribbon tight, but every time i close the lid it starts winding ribbon and errors out... we've always had to do this, but it's always worked after a few to several trys...
is there a best way to do this?
  • crhoden Sep 11, 2008
    QUERY PRINTER RESULTS
    Connected Via USB
    16:37 11-9-2008
    PCB version : 2
    Firmware : EV3.18
    Serial No. : 45E3178
    Product ID : 3800
    Image Start : 100
    Image End : 25
    Printhead Density : 3080
    Last Reported Error -
    Unable to determine the film type. Please check film and try again.
    Error Code - 07:03 - "dye_film.c" : line 92
    Locking Code : 0
    Holokote horizontal position : 100
    Holokote vertical position : 100
    Default Smart Card Position : 23
    holoPatch Hole Top position : 100
    holoPatch Hole bottom position : 100
    holoPatch Hole left position : 100
    holoPatch Hole right position : 100
    THM : 0
    Eject Speed Index : 0
    Ramp Adjust : 50
    Fast Resin : 1
    Cleaning prompt is DISABLED
    Cleaning overdue? : NO
    Cards between cleaning prompts : 350
    Cards since last clean : 48
    Panels since last clean : 216
    Total cleaning cycles : 2
    Cards printed on printhead : 84
    Total cards printed : 1
    Total panels printed : 412
    Panels remaining : 60
    Current language id : 0 (ENG)
    Chip contact mode : 0
    HoloKote Key is not present
    Tiling Flag : 0x0
    HoloKote Key is Multi Tiled
    X Coord : 0
    Y Coord : 0
    Printer Locking Code : 0x0
    Tachos per panel : 0
    Eject Enabled
  • exclusiv_22 Dec 28, 2008
    dye film barcode error when turn on the printer
    Scholar:
  • 71 Answers
Hi There,
There is no need to set the ribbon tight. This will be re-initialised each time the lid is closed or the printer boots from being switched on.
The error message and number is important. Depending on which driver you have installed, you may not see the error message on the status monitor. However you need to know what the error is, and most importantly, the error code (04:??).
To see what the error is follow these instructions;
Switch on the printer and let it try to initialise. When it errors and the Red LED is flashing,
Download and install the Magicard Support Utility (V3.14).
You can get this here;
http://www.ultramagicard.com/support/technical-support/?R=&L=&id=&lang=1&printerID=9&supportOption=3
Run the Magicard Support Utility. Select 'USB' for the comms port. When the other tabs open up, select 'Query Printer'. Click the 'Query' button. The left-hand pane will display the result of the query.
About a third of the way down is the 'Last Error Reported' line.
What is the last reported error (and crucially the error number)?
From this I should be able to tell you what to check.
Also, have a look at the following;
http://www.magicardonline.net
Enter your printer's serial number in the QuickSearch box.
You will see the printer's current warranty status as well as all the latest driver / firmware downloads and more.
Magicard will still offer you lots of support whether the printer is in or out of warranty.
With Best Regards,
MC.
Posted on Sep 10, 2008
  • Magicard
    Magicard Sep 15, 2008
    Hi There,
    Sorry, but I thought I would get a reminder if you posted a comment! I see you added the query information the next day. Sorry for the delay.
    The error number 07:03 indicates that the printer has not identified which dye film is in the printer.
    It does this by reading the barcode on the clear spool. The barcode sensor is at the bottom of the rear left-hand dye film clip. Please chech that the metal cover with the thin slot in it is clean.
    Check also that the barcode on the clear spool of the dye film is not damaged or obscured in any way.
    I checked the warranty status of your printer and it is still under warranty until 13.11.2008.
    I assume since the warranty is one year that this printer is neither within Europe or the USA?
    If necessary, it can still be returned to Magicard for repair under the warranty.
    It would be worth contacting Magicard directly, as we could probably resolve your issue much faster.
    Please use the following link to submit a support request;
    http://www.ultramagicard.com/support/tec...
    While you are waiting for a response, I would try updating the firmware to the latest version which is currently V3.18. You can download this here;
    http://www.ultramagicard.com/fileadmin/i...
    To install the firmware, just make sure the printer is powered on and connected to the PC. Then run the update utility downloaded above. Click 'Update', and about 20 seconds later the printer will re-initialise with the new firmware version.
    I hope the information is useful to you.
    With Best Regards,
    MC.
  • Magicard
    Magicard Mar 31, 2009
    Hi There,
    Upgrade your Avalon's firmware to the latest version (V3.24).
    http://www.magicardonline.net/results.ph...
    If the problem persists, your printer is still under warranty, so you can contact Magicard's Technical Support and have the printer repaired free of charge.
    Contact Magicard here;
    I hope this helps.
    Regards,
    MC.
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
My printer has stopped printing the letters onto the dvd properly
1. Remove lid/top
2. Move blue lever left or right to unlock ribbon roll
3. Loosen ribbon or tighten as needed -
NOTES: If ribbon roll is too tight it will show wrinkles; it should look smooth if positioned correctly; if too tight it will not print portions of some letters; keep re-positioning if this does not work after first try.
4. Use flat-head screw driver to adjust front uptake (used) ribbon-roll as needed to make it smooth too. Lift out & re-position, if you need to.
THIS WORKED FOR ME but I had to re-do my re-positioning of both rolls several times before it began printing 100% of letters again. 4bb240d8-5e9d-4611-9ca4-33b5883e40b9.jpg 5a5b4381-7ee8-480f-943e-041aa738011d.jpg c86d59ae-1b7e-4755-b895-08007064e847.jpg Journal Kentucky Lexington Monitor www jklm us
May 20, 2010 | Rimage Perfect Image Prism Thermal Printer
How do i reset the wheel on a smith corona sl460 electronic typewriter? the correction ribbon keeps coming out of place
The typewriter has a spring at one spool to keep the correction ribbon taut. If that spring is broken or out of place, the ribbon will always get in the way of the wheel.
If both ribbons are correctly set tight between the wheel and the paper, the typewriter will reset the wheel at power-on.
Some models reset the wheel every time you close the cover. You can see and hear it if it does.
Feb 16, 2010 | Smith Corona Office Equipment & Supplies
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Printer prints too light and not threw all copies of form
If you lift the lid open do you see a lever to adjust the printer head closer to the paper?
Jun 23, 2008 | Panasonic KX-P2023 Matrix Printer
Battery compartment
same problem , no solution, i e-mailed like 10 times to buy ine cover lid, i think they re out of business
Nov 11, 2007 | Cameras
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Magicard Avalon Duo Thermal Card Printer Logo
263 people viewed this question
Top Magicard Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
