Question about U-Line 75BWC
U-Line 75BWC I have a U-Line 75BWC that is about 10 yrs old. The light comes on when I open the door but the motor no longer runs/cools. I saw somewhere else on here that the problem may be the thermostat. How would I know for sure and how easy is it to fix? How much would it cost to have someone else fix it approximately?
  • jdodaro Sep 05, 2008
    how do I easily get to the wires?
    President:
  • 1,462 Answers
If 10 years old then probably has a phial type thermostat. this may have 2 or 3 wires to it plus earth. connect all the wires together (but not earth) and if it is a stat problem, the compressor will start
Posted on Sep 05, 2008
  • douglas smith Sep 06, 2008
    already sent you a reply on another post
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Fridge/ice maker not cooling but lights on and fan is running. How to check if it can be repaired or not?
Unless you tell us what the unit is doing and not doing you might as well just go out and pound some salt!
Nov 22, 2015 | Refrigerators
Refrigerator runs all the time and ice cream is too soft.
Thank you for contacting fixya.com.
There are various reasons why a refrigerator keeps on running.
The motor will run longer under warm conditions or if the refrigerator is receiving direct sunlight from a window or door. At normal room temperatures, your motor will run about 40% to 80% of the time. Under warmer conditions, it can run even more.
A recently installed refrigerator will initially run more while cooling. Allow 24 hours for the refrigerator to completely cool.
When large quantities of food are added, the refrigerator has to run longer to cool the new items.
The motors will run longer when the doors are frequently opened. Conserve energy by getting all items out one at a time, keeping food organized, and closing the door as soon as possible.
Also a worn door seal or gasket in refrigerator or dirty condenser coil can be the reasons for refrigerator to run long.So you need to consider all these factors troubleshoot your problem to your refrigerator.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | GE Refrigerators
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Feb 15, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
My refrigerator stopped cooling, but I still have power and lights, however, my digital cooling settings are no longer lit. Is it possible my board is bad and how do I go about fixing this problem, or can...
check back side of your fridge touch the motor compressor running or not if not running check the electronics board and make voltage check from electronics board to motor compressor. if the compressor running touch the one side of copper tube if have hot one side. if have hot your freon ok check the cooling fan inside the freezer side ok good lock
Jan 01, 2010 | Refrigerators
I have a side by side fridgeits about 10 yrs old
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
Aug 26, 2009 | Refrigerators
Neither the freezer nor the refrigerator is cooling properly
Check the evaporator coils on the back to see if they are warm. The cooling coils are supposed to be real cold. Sounds to me like you are low on refrigerant, and have a very small leak somewhere. I can't fix that from here, but service tech can find leaks, and recharge, but find cost first as you might just want to buy a new one as the other one is 10 yrs old. Hope this helps you, Rick
Apr 26, 2009 | Refrigerators
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Unit not running (cooling)
Hi ,
My fridge motor will not kick in or make any sort of sound, there is light on in fridge, where would I find the fuse or overload button.
I need help, thankyou. Coaxing.
Jan 18, 2008 | Refrigerators
feel the motor and see if warm. if so and not cooling then that is where problem is. more likely is the thermostat. (ignore earth wire to stat). this can be 2 or 3 wire usually. short together and see if compressor starts up. if so thermostat is at fault.
Apr 24, 2007 | U-Line 75WC Wine Cooler
Refrigerators Logo
218 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
