Question about Linksys Wireless-G WUSB54GS 802.11g/b
Hi i have a link sys adapter wusb54gs and a netgear WGR614 router?
I added the drivers and it show up that it can see networks mine and others all psk but when i add the psk for my router it says "cannot connect to the action source"
Any ideas am i putting the info in wrong or are these not compatible Thanks
  • Anonymous Sep 26, 2008
    will noit connect
    Genius:
  • 1,689 Answers
If you have installed the device on an XP sp1 and does not have the PWA patch this will be the error. it will be best to contact your Linksys Tech support at 1-800-326-7114 and they may need to install the adapters wireless utility to get you conencted.
Posted on Sep 05, 2008
Need help with a wusb54g ver4 network adapter
You are say link light means network light not on. Then you check network cable because network cable not proper response not link light on. or check you not break any cable. If possible reset Linksys adapter and wait some time then open and configure i hope solved your problem. If not solved then contact Good network engineer.
Thanks.
Computer Support
Mar 06, 2014 | Linksys Wireless-G Broadband Router
I would like to change my pasword
most likely you will need to remove the program from the computer and then reinstall. then you can make a new password.
Sep 15, 2012 | NetGear WGR614 Wireless Router
How to lock my router
in your browser type in 192.168.1.1 or 192.168.0.1 ( usually the first one)
when prompted for username type admin and password admin
Select "Wireless Settings" from Setup Menu in left hand navigation bar
Under "wireless network" type in your desired network name in SSID box
Under "security options" select WPA-PSK [TKIP] + WPA2-PSK [AES]
Enter your desired password into "passphrase" box
Click Apply
http://kb.netgear.com/app/answers/detail/a_id/112
May 04, 2011 | NetGear WGR614 Wireless Router
IT SEEMS LIKE OTHER PEOPLE IS STILLING MY WIRELESS. TELL ME HOW TO BLOCK IT
Use WPA-PSK and WPA2-PSK. WEP security is not secure at all. Change your SSID to something you recognize. The default is NETGEAR. everyone who buys a router may have this name. MAKE it your own SSID NAME
check in the DHCP client list to see if only your pc's are attached. I am sending a user manual link to get you started.
ftp://downloads.netgear.com/files/WNDR3400_SM_23MAR2010.pdf
This is a tutorial for the netgear router in general to make a secure network for wireless.
http://www.ehow.com/print/how_5008833_set-secured-wireless-network-netgear.html
Mar 24, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
How to set a security cod for wifi
This is a Quick and easy fix!
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Dec 12, 2010 | NetGear WGR614 Wireless Router
I want to set up a secure netgear wireless connection
THIS IS A SUPER QUICK AND EASY FIX!
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  4. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  5. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  6. Click Apply to save the settings
Dec 11, 2010 | NetGear WGR614 Wireless Router
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
How do i reset password for netgear router
There should be the reset button behind the router, click on it for about 5-10 seconds.
Jun 26, 2010 | NetGear WGR614 Wireless Router
Accidentally unplugged our WGR614 v9 netgear router and now my other computer and xbox 360 will not pick up the wireless network anymore
yup its possible that the configuration on the wireless networking adapter, was like removed..
just configure it again..
Dec 01, 2008 | NetGear WGR614 Router
Wireless router netgear
Is it possible to download the drivers for Netgear wireless router & Voice adapter WGR613VAL
Nov 02, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G WUSB54GS 802.11g/b Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
