Question about SanDisk Sansa e250 MP3 Player
How to charge the battery of my Sansa e250MPE
Some one can help me please, I bougth a a USB-AC but this is only to use when I plug it. Thanks
  • 8,596 Answers
Plugging it into computer via the usb cable that came with it is the best/fastest way to charge the player.
Posted on Sep 05, 2008
Can I recharge the battery of my Sandisk Sansa Clip MP3 player without using my computer?
Yes. AC to USB adapters are available anywhere cell phone chargers are sold. One end plugs into a wall outlet and you can plug the USB cord from your Sansa into the other end. I use such a device every night to charge my Sansa.
Aug 25, 2011 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
Charging
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
Jul 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Does not charge
Below are some things to check for when your Sansa player does not charge..
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Also try ports on the back of your computer, these ports have more available power. Some computers have limited power to charge up the device...
Jun 08, 2010 | SanDisk Sansa Fuse MP3 Player
Battery wont recharge-
Below are some things to check for when charging your Sansa player:
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
To Remove the Battery... 1. Remove the back on the e200 by removing the 4 screws. 2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove. NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player. 3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player. 4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place. 5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable. 6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device.
NOTE: If the device goes directly to a black screen after unplugging it, then the battery has been replaced incorrectly. Take the back off the player once again and flip the battery around and the e200 device should work properly.
May 31, 2010 | SanDisk Sansa e250 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
Jul 17, 2009 | SanDisk Sansa Clip MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
