Panasonic SC-AK17 Shelf System
Problem for Panasonic SC-AK17 Shelf System
Panasonic sa -ak 27
By ghoststyle on Sep 05, 2008
i have a f 61 error
Comments:
Sep 05, 2008
- but the demo is stil going is that normal ?
Best Solution
posted on Sep 05, 2008
Helpful)
tech48
Rank: Guru
Rating: 94%, 542 votes
This is a common error for these Panasonic units. I work at an authorized Panasonic service center and have repaired many of these.
This error is caused by either 1 of these 2 problems, both of which will require service for replacement of parts.
1. The amplifier IC is bad and needs to be replaced.
2. There are a couple of smaller components in the amp circuit that need to be replaced. One is a zener diode and the other is a resistor.
The F61 error is caused by a bad amp circuit or power supply circuit. In most cases it is the amp circuit. More often than not, it is the zener diode and resistor that are bad. This would be preferable since the amplifier IC is very expensive and a total repair cost would be close to $200. The zener diode and resistor repair would be closer to about $100 depending on the rates of the service center.
I know this may not be the answer you were hoping to get, but it is the problem you have.
If you found this information helpful in making a decision on what to do with your stereo a FixYa! rating would be appropriate and very much appreciated, after all, it is the only reward we get for offering free help to people like yourself.
If I can be of any further help just reply to the post and I will get back to you as soon as I am able.
Good luck with your stereo, I hope you found this information to be helpful.
Dave
Comments:
Sep 05, 2008
- Normally the demo mode would not come back on, but it would not be totally unusual if the unit was sitting for a while still plugged in and then the demo mode turns on. It is best if you unplug it and do not attempt to turn it on anymore until it is repaired. Every time you turn it on a surge of current goes thru the amplifier circuit and can cause more damage because the faulty parts are causing more of a current draw than what is normal, and that can cause other parts to short out from repeated excess current being pulled thru them since it would be more than the normal amount of current that they were designed for.
I hope this helps, and thank you for the FixYa! rating. It was very much appreciated. I hope you have a great day!
Dave
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Panasonic SC-AK17 Shelf System
Questions and Unsolved Problems for Panasonic SC-AK17 Shelf System
Do you recommend Panasonic SC-AK17 Shelf System?
Answer
Answer
can i get another remote for a panasonic stereo system SA-AK27 if i can where from
Answer
Bought the unit used. when you turn it on it is in CD mode, the drawer comes open and says remove... (More)
Answer
following a power outage the system came on automatically and will now not turn off. Otherwise works... (More)
Answer
A few months ago I could not get any sound on cds, recently I could no longer get sound on the... (More)
Describe your Audio Shelf Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf... Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
