Question about Cell Phones
Intial charging period
I just got the lgkc550 and its intial charging session has lasted over 30 hours....and its still charging... is this normal? wat is the max time it will take?
  • 35 Answers
Yes its pretty normal the max is 36 hours for the first time to open all the cells ,after that when u charge it the current will flow in
Posted on Sep 05, 2008
Why did weed eater just stop working?
Take note: The battery pack will not reach full charge capacity on the first few charges. The break-in period requires 4 to 5 charging cycles, where the battery pack is completely discharged ( no motor sound or tool motion) and then fully recharged. During the break-in period the battery needs to be charged 5 or more hours continuously. The green LED light on the charger will come on in 3-5 hours,this is normal, Continue to leave the battery pack chargingvfor a total of 5 hours or more. After the break-in period, a full recharge is indicated on the charger when the green LED light is lit. Note: Do not charge battery in areas lower than 50 degrees or higher than 80 degrees. Looks like this will need to be charged in the house. I found all this information on page 14 in your manual.
Jul 18, 2015 | Garden
New tablet only using up to three hours and battery needs charging is this normal.
Yes, that's pretty normal. You can make it lasting longer just by lowering brightness.
Feb 27, 2015 | Cell Phones
Charge time
Around 2 hours for initial charge. I've had 30 minute charges recently on a used system. I would consider a charging station that is in a handy location so then you can keep it constantly charging and still easily accessable when you are ready to begin your blood sessions.
Jun 09, 2014 | Sony Playstation 3 (PS3) Console
I want to make myself a medicine ball training program, do you have any advices?
If you want an effective practice, it should last 30 to 40 minutes, allowing you to break a good sweat and build a calorie-burning heart rate. You should perform your workout about three times a week with 36 to 48 hours of rest between sessions. Each session should contain at least two sets of eight to ten exercises.
Aug 05, 2012 | Exercise & Fitness
My computer doesnt recognise the ac power charger
The DC jack in the laptop is a common source of trouble, and in this case may need to be replaced. The computer will need to be dismantled down to the motherboard to address the issue.
May 01, 2012 | Samsung R730 Notebook
FS240BX battery how Long should it take to charge.
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
Jan 22, 2011 | Black & Decker Firestorm Slide Battery
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
How long will a 100 amp battery run a 30 motor att 2 speed ?
The Endura 30 draws 30 amps at the highest setting (5), so it'll run 100/30 - 3.33 hours with a fully charged 100AH battery. At setting (4), it only draws 15 amps, so it'll run 100/15 = 6.6 hours. At the lowest setting, it draws 3 amps, and should run 33 hours.
Feb 12, 2010 | Minn Kota Endura 30 Freshwater Transom...
How long does the soak programme last?
For this machine the length of time of between 30 minutes and 2 hours can be programmed in 30 minute increments for the soak process.
The machine is set ex works with a soak period of 2 hours.
To programme in a different soak period see "Programmable functions - Soak" in your user manual. See Page 59.
Oct 16, 2009 | Miele Novotronic Premier 500 Front Load...
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
