Question about Nikon Coolpix 3200 Digital Camera
Viewfinder Obstruction A black dot has appeared inside my optical viewfinder and is very annoying. Is there anything I can do to remove it.
I have the same problem in the corner of my view finder the rest of it is just gray.........I can't take pictures or view the ones in my camera.........any suggestions on how to fix this??
Posted on Jun 14, 2006
    Novelist:
    Champion:
  • 277 Answers
If the dust/dirt is visible in the finder, it is in one of three locations: - if very sharp, it is on the "grind" side of the viewing screen, which, unfortunately for cleaning ease [unless the screen is user-removeable], is often the upper side of the screen in newer cameras. - if fairly sharp, it is on the non-"grind" side of the screen, and it may be possible to remove it with a VERY soft (very clean!) small brush or a VERY gentle blowing with a hand syringe-type blower (blowing hard into a VF area just about guarantees that dust will be blown in). - if very soft-looking, it is on the underside surface of the pentaprism (being able to clean the VF area without a repair is an excellent arguement for having the interchangeable-screen feature...). Prevention is the best way - never leave the body cavity uncovered (except briefly, when changing lenses); never change lenses in a windy area; keep the rear area of the lens clean; get in the habit of facing the open camera downward while changing lenses; NEVER blow into the body cavity (unless you know what you are doing, the mirror is up, or the screen is removeable). Hope This Helps
Posted on Oct 30, 2005
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Optical viewfinder vignette problems
Sound like the focus screen and frame fell out
Mar 22, 2012 | Canon EOS 5D Mark II Digital Camera
The screen of the viewfinder has a black dot.. i tried to clean it but it cant be removed,..how can i removed it?
Remove the lens of your camera, do it in a clean room, look at the mirror insie the lens to see if the dot is not there rather that on the outside of your viewfinder.
If it is not there it might be on the inside part of the focusing screen. Still inside the camera look at the upper part of the body, the focusing screen looks opaque.
If you still cant find the dot it might be on the inner side of the focusing screen.
Here is a tutorial on how to remove it on a d70 it is essentially the same thing on your camera.
Otherwise it can also be on the inner part of the viewfinder. In this case I recommend to send the camera to a repair shop as the removing of the viewfinder seems to be more difficult on the d3000 than on other camera.
Hope this helps.
May 30, 2011 | Nikon D3000 10.2 Megapixels SLR Digital...
There is some black unremovable dots (not visible on sensor sirface). Is IMAGE DUST OFF REFERENCE DATA helpful to remove that black dust like dot from image? how can I use that feture?
Black, unremovable dots are probably bad pixels in the sensor. These are parts of the sensor that no longer react to light. If you don't see any issue looking through the viewfinder, then the sensor is messed up. Since you say you don't see anything on the surface, I assume the optical part of the camera is in tact. You can try cleaning the sensor - Menu - Setup - Clean Image Sensor - it certainly can't hurt.
Nov 06, 2010 | Nikon D70s Digital Camera
Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Mar 31, 2010 | Canon PowerShot SD430 / Digital IXUS...
There's an insect in the viewfinder... IHow do I remove it?
There is lock on black portion of view finder push it and turn it anti clockwise it will open and use hand blower n clean it
Mar 06, 2010 | Sony Handycam DCR-TRV103 Digital Camcorder
Image through Nokia F80 viewfinder dark and cloudy
Please also ignore this answer, (see askers comment above). I've only posted it so that this question doesn't continue to appear as an unanswered one.
If anyone else has this problem please go to
http://www.fixya.com/support/t2637498-image_nikon_f80_dark_cloudy
for an answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Sony DSC-V1 optical viewfinder has a horizontal line in it
It shouldn't be there, but as the optical viewfinder is completely separate from the photographic light path it's nothing to worry about either.
Normally it's caused by either a hair or fibre which has somehow entered the viewfinder (rare) or more commonly by a fine scratch across the front window to the viewfinder. Also check the rear viewfinder viewing lens as the same damage could occur there but as that lens is relatively protected it's unlikely.
Any further fixing involves dismantling the DSC-V1 and possibly sourcing spares made of purest unobtanium so if the camera works perfectly well then leave the screwdrivers safely in the toolbox for now.
Feb 21, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
View finder focus
Is there a little black wheel or anything beside the optical viewfinder that turns? If there is, turn it until the image comes into focus.
Aug 17, 2007 | Canon PowerShot S2 IS Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
124 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
