Question about Logitech Z-2300 Computer Speakers
Z-2300 noisy speaker
My brand new left speaker is noisy and the sound is distorted. sounds like static of sorts. changing position and location does not help. it seems to get worse when i raise the volume. any suggestions?
  • mano_har_200 Aug 26, 2008
    My 2.1 speaker is creating noisy out put after formatting recently. tried installing the mother board audio drivers, still the same any good suggestion,
Try muting the input monitor on ur sound...
Posted on Oct 14, 2007
    Champion:
  • 277 Answers
Ur speaker is bad probebly torn membrane try replacing it (or disconnecting) this speaker there is a special kind of glue for membranes .... try it good luck windman
Posted on Feb 13, 2006
Right speaker channel doesn't sound clear anymore
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Nov 17, 2014 | Audio Players & Recorders
Can't tell where positive and negative are
a simple aa battery and a couple pieces of wire is all you need,connect wires to the speaker and then by attaching the wires to the end of the battery you can make the speaker move. when the speaker moves out follow the wires just as they are on the battery . the positive side of the battery will be the positive to the speaker. hope this helps.
Apr 05, 2013 | Car Audio & Video
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Left speaker sound is distorted can Ireplace one speaker
Yes, you can check left speaker by replacing it or by interchanging with the rightside speaker. If the speaker is okay, then check for faulty amplifier circuit board. Don't forget to check the dirty EP socket or banana pin for leftside speaker.
Sep 22, 2010 | Logitech Z-2300 Computer Speakers
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Radio wiring ford xg ute
On new systems, like the one you bought to replace old one: grey and white are front, purple and green are rear. New wires should be labelled or shown on diagram on radio body. Stripes indicate negative side of speaker.
On your old loom: cut back behind plug, and strip wires at ends. Isolate power and grounds, and any that go hot EVER! Now checking just the remaining wires, use a AA or 9-volt battery, and touch pairs of wires to opposite poles of the battery. If you touch two that go to the same speaker, you will hear a slight static sound at that speaker: label these for that speaker, and so on. Once you get the pairs seperated and labelled by speaker location, the negs will be the striped ones, though you may not find they all have stripes. once you pair them, test in both polarity positions, the correct one will sound better right away. Should be able to reach max volume with little buzz or distortion. If not switch pow and neg sides. Hope this helps, TT
Feb 11, 2009 | 1995 Ford Ranger Supercab
No sound from speaker
My speaker did the same, brand new out of the box, but I ran TomTom Home and it upgraded my firmware. Since then, no issues, and perfect clarity
Dec 07, 2008 | Tomtom GO 730 Car GPS Receiver
Left Speaker Problem
Sounds like the left channel in the built-in amplifier went out or possibly damage in the connector or cabling. Quick test to eliminate the PC is to connect another set of working speakers or headphones into the PC speaker jack without making any changes. If it works w/o problems then it?s the speakers. You can try plugging the speakers back into your PC and while playing something start wiggling the left channel cables and the main cable that goes into the PC. In particular pay attention to stress points like connectors. If that turns up nothing and you have the appropriate tools and skills you can open the speakers up and test out the solder points for the cables as well. As always make sure your warranty has expired completely before you open them up or start cutting away. Let us know if you have any other questions and please don?t forget to rate this post.
Apr 12, 2007 | Logitech Z-2300 Computer Speakers
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
Logitech Z-2300 Computer Speakers Logo
187 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
