Question about Toshiba 53H71 53 in. Rear Projection Television
I have an RCA scenium tv 52" hd tv. what are costs to fix convergence?
I have a 52" RCA HD. I turned it on and for a few minutes it played great. Now the screen appears warped on the top and bottom.
This is a 52" RCA DLP projection tv correct?Yes,than a problems,u have is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 14, 2010 | RCA Televison & Video
Got and RCA Scenium CRT HDTV (D52W135D) which seems to have a convergence problem, green shadow over picture. DVD picture is very dim also
This tv have 2 problems than,the tv projection lamp life is over,that why the picture is dim,must be to replaced with a new picture lamp.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.Replaced all these parts to solved the convergence problems.
Jun 24, 2010 | RCA D52W135D 52 in. TV/DVD Combo
There are 3 distinct colors showing up almost like a 3-D image. red, blue, and green. What is the problem and how much would it cost to fix in a RCA Projection HD TV 52 inch?
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 31, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Going to an ant on my TV
NO!!!!!!! You are HD Ready if your TV is HD if not then you will need converter box to recieve channels from a antenna,.
Dec 30, 2008 | Televison & Video
Rca d40w20 tv convergence and power on problems
It is possible, if you do not have experience in fixing tvs is better replaceing the whole convergence board.
You should be able to find parts here.
Nov 07, 2008 | RCA Scenium D40W20 40" Rear Projection...
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Convergence
oki this is an itc 222 or rca hd 52.... if your convergence option is not availvble in your menu and you have a bowed multicolored 3 d ish picture then this points to a special fuse fl231 if you can get this fuse and can solder then it should cost you about 5 bucks and 30 minutes to fix...ill give you more intstruction on how to do this repair. whats your model of your tv]
May 23, 2008 | RCA HD52W59 HDTV Projection Television
Converges problem for my RCA 52
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HD65W20JX1 RCA SCENIUM THOMPSON MULTIMEDIA
looking for an owners manual for the D52w20 RCA 52 Rear Projection TV.
kimmipoo_2000@yahoo.com
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 53H71 53 in. Rear Projection Television Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
