Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice dispenser door hinge bracket broken
My indoor ice dispenser door hinge pin bracket on right side broke off. It is part of the molded housing. Whirlpool service says the entire freezer door has to be replaced and they refuse to sell the recessed housing which shows up as Part #1 on the ice/water dispenser diagram.
I think I can fix this if I can get the housing out of the door, drilling 2 small holes through the housing and using wire like a bread tie to hold the hinge pin in place.
What's involved in removing the housing from the door?. I'm able to remove all of the other parts of the ice/water dispenser brackets, levers, doors and parts. Looks like 4 screws hold it to the door.
Or is there some kind of a repair kit that can be attached to the ice/water dispenser housing without removing this housing?
  • patsyb Sep 22, 2008
    To : HUUUM
    Is this where I reply to your questions?
    This side by side unit is about 18 months old. A new door is about $600 - $900 depending on who you talk to and the labor is about $150, maybe more depending on how long it takes the tech,
    Thanks for taking the time to comment on this problem.
  • Anonymous Oct 03, 2008
    they do have a repair kit with a metal peice that will never brake!You can get this from Whiripool
  • 8 Answers
I repaired this problem on my Whirlpool fridge with a metal bracket that I designed and installed myself (see photo). I can supply detailed, step-by-step instructions, complete with lots of photographs, to do this repair. I get these brackets water-jet cut in quantity so the quality will be good.
I will sell the instructions, bracket, and attachment screw for $70, or a more complete kit with the bonding compound, drill bit, and chisel (so all you need is a drill and screwdriver) for $100. I think this is fair for the development time, prototypes, and mass production costs involved, and is far cheaper than the $560 Whirlpool wants for a new door. You can do this repair with the freezer door in place, and it should take you only about 2 hours, not counting the 24 hrs to wait on the bonding compound to set up.
E-mail me (jeff at if you're interested, and please put "refrigerator" in the subject line. This repair was done on Whirlpool side-by-side refrigerator model ED5JHGXRQ (white), but should also work on ED5JHGXRT (Biscuit), ED5JHGXRB (Black), and ED5JHGXRL (Stainless-VCM).Ice dispenser door hinge bracket broken - ae8679c.jpg
Posted on Sep 24, 2010
  • Jeff Lentz Sep 24, 2010
    In searching more, I found there is a repair kit that has a bracket similar to the one I designed, and it appears to attach with a screw, just like mine. It's listed in several places ( among others) as "Whirlpool #8201756", and you can probably buy it cheaper than mine. Of course, I didn't know about it when I made my own. I think mine's more substantial, but otherwise, it may work fine for this repair. Whirlpool apparently doesn't want to divulge this information unless pressed on the issue, as they would rather sell you a $560 door.
  • 750 Answers
Hi patsyb,
I under stand your frustration.
I see this everyday.
Many people call service for problems with their ice maker or fridge icing up
and most of the time it is related to that door you are referring too!
This door must be perfectly aligned and sealed!!!!!!!!
Even a tiny bit off that you can not see with your naked eye and icing problems begin.
It will allow air to seep in from outside which will result in ice forming every place that no one wants and or needs it to be!
We have people calling all day in service with ice forming problems related to the ice maker on all brads of side by sides and the service tech some times comes out 2 or three times ordering and changing parts till he finds the correct one , OR the whole door unit is replaced as they told you about!
If you drill wholes and hang it with wires as you spoke of, you will have so many problems you will wish you did change the whole part!
Now another point is the question?
1. How old is the fridge
2. How much do they want for the replacement of the whole inside part and labor?
Let me know what you do and if you have any more questions!!!!!!
Please remember to give a rating before you sign off or after you decide that I really did give you good solid,fatherly advice in your best interest!
Bless you,
Here is a report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Posted on Sep 22, 2008
  • Neil Golan
    Neil Golan Sep 22, 2008
    Hi patsyb,
    HOLD THE PRESSES!!!!!!!!!!!!!!!!!
    I have the solution for you!
    It's a little long but I think I can tell you how to get it done for FREE!
    We are a family run appliance business for 65 years and this procedure is used by every
    manufacturer in the USA.
    It's called a push pull!
    They even call me from whirlpool trying to coerce me to do this for them!
    Here is what you must do!
    I do this a lot for my customers!
    We are a family business for over 65 years
    You get together all the service invoices and organize your self with the sales slip and service slips and call whirlpool,"Consumer Affairs" 1-800-253-1301
    DO NOT USE OUR industry terminology, "PUSH-PULL"
    Then we are going to get them to do a whats called a "PUSH-PULL"!!!!!
    You tell them when you bought it and how many times service has been to your rescue! With documentation of dates
    Be calm, nice and reserved! BUT FIRM!
    You want them to replace this lemon with a brand new machine! And ask them if this is a model flaw .That you want another machine with an up grade so you are not going to go through this again with this model!
    Not even delivery.No matter what the dealer says to you about money! No money, honey! Got me?The companies forbid the dealers from taking any money from the push pull customer !
    They pay us!!!
    Unless you want to tip the guys on the truck.
    Some times I've told my customer that when it's a lot past warranty that for good measure, Tell them,
    "I just took a loan to remodel my whole kitchen, and I have gutted the kitchen and found all my stainless steel Whirlpool Gold appliances that I am ready to purchase BUT !
    But I cannot in good faith follow through with this buy until I see that Whirlpool does indeed back up their product!
    Your going to love the service and being in control!
    You are fine now!
    All will be right!
    They will fix it for free or swap it out for a new one.
    I believe this time they will rather change the door at no cost to you!!
    We started with appliances 65 years ago and still sell them TOO!
Kenmore elite 106.44423603 ice/water dispenser housing - plastic broken off for ice door pin hinge. Any ideas for a fix?
Hi and thanks for using fixya!
There is actually a "kit" that replaces the hinge, housing for the hinge, dispenser door and bracket. Just be sure when you're taking everything apart you pay special attention to how it goes back together. Kit comes with metal bracket that will replace old housing. Now that I think about it the kit comes with instructions! Kit pt# 8201756 and you can purchase it here. Appliance Parts
Feb 04, 2015 | Kenmore Refrigerators
Ice dispenser door came off and inset plastic retainer gone and now way to repair as pin has nowhere to sit. gc3shexnq03
There is a kit that fix that problem it has a metal bracket that replaces the plastic one that broke
Nov 09, 2013 | Whirlpool Refrigerators
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Spring on the ice dispenser arm is off the shaft pin.
on this type of model the hinges that the door chute is on is week check what part is broken it might be just something holding it open but if its hanging there need to check if the hinge on the dispensor housing itself is broken. if it is they sell a ice door kit for this model due to the weak plastic it sits on
Nov 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
I have a Whirlpool side by side with an ice dispenser. The little door that closes on the outside opening of the ice dispenser has come loose from its bracket. I cannot get to it to reattach it, or even...
if it has become loose, the pin that holds the disp door came be put back into place. if the plastic tab that holds the pin into place broke, you will need to have a kit installed that has a metal bracket. that should be done by a tech. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
Ice dispenser is clogged with cubes frozen together. Will not dispense.
Your ice dispenser door may not be closing tightly, allowing air to leak in causing it to frost up and block the ice.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Oct 09, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
The door flapper on the ice dispenser is not closing. this causes ice and snow buildup on the inside of the door and ice will not dispense
There is a solenoid that operates the door that could have stopped working. Can you hear it? The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Jul 12, 2009 | Refrigerators
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool pin retainer is broken on ice dispenser
this is easy. there is a small area beside where the piece broke off. bend a small peice of metal coat hanger at a 90 degree angle, (this is so you can make your new hole on the correct line) heat the end with a lighter, burn a smallhole thru this area beside where the previous hole existed. now throw away the old pin that you were using and use a piece of coat hanger cut to the right length. on one end bend about one half inch to 90 degree angle, feed thru new hole and thru your spring and flap and thru to opposite side hole and lastly make small bend to keep wire from sliding out. ta da, fixed. problem solved for about two cents. i have successfully repaired many of these doors.
Oct 09, 2007 | Whirlpool ED2FHEXN Side by Side...
Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. back
Dec 18, 2006 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
776 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
