Question about Amana 3.2 cu. ft. Top-Load Washer
Stall in rinse cycle
Amana distinctions washer stalls at the rinse cycle, won't progress or fill with rinse water, even when moved manually
  • wizardofeyes Oct 08, 2008
    thanks to aborcass for the suggestion...as it turns out, this washer has VERY ambiguous Hot and Cold markings, and I had reversed them. Washer works fine once they were reversed!
    President:
  • Amana Master
  • 2,651 Answers
Loks as if its been amonth since this post, but i would chek your cold water supply, common problem
Posted on Oct 07, 2008
Whirlpool wont spin on rinse cycle
What is the model number??
Jun 28, 2013 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
    Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
    Dec 03, 2017 | Whirlpool Washing Machines
    AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
    Hello Daddy 2,
    Welcome to fixya
    I'm Huuum and happy to assist you,
    What is the model number and the year of the washer?
    Front load or top?
    A waiting your response!
    Huuum
    Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
    Amana 3.2 cu. ft. Top-Load Washer Logo
    269 people viewed this question
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
