Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Fan constantly working
Is it normal for the PE16 (right) fan to constantly work? even on standby?
    President:
  • 2,072 Answers
It is normal, it runs all the time. But normally the fan is so quiet, you do not notice it.
What you need to do is carefully remove the cover from over the fan. On that fan there is a gold or solver label, peel that off, and behind that label, there is a rubber cap over the fan bearing. Pop that cap out and lubricate the fan. It will then not be noticable, it runs in slow speed all the time like your power supply cooling fan on your computer, but you really shouldn't notice it. It's pretty common for that bearing to get a bit dry and make the fan operate noisily.
Make sure you replace the rubber cap over the bearing. And if you have any electrical tape, clean the excess oil off the cap and just put a small piece of tape over it so it does not vibrate off.
That will be your fix. Have done it a few times to that particular machine.
Posted on Mar 23, 2008
    Champion:
  • 277 Answers
This means that the device is overheating try puting it away from the wall or in a free air space so the unit will be able to cool itself properly good luck windman
Posted on Feb 13, 2006
2001 Honda Foreman 450es is it normal for the oil cooling fan to come on and off when trail riding thanks
Seems normal to me. An oil cooler fan works to keep the oil cool just like a radiator fan works to keep the coolant cool. It doesnt necessarily run constantly but it kicks on as needed.
Nov 07, 2016 | Honda Motorcycles
Does the fan in the DVD video recorder/ video cassette recorder\r\nD-VR7KC2 always run even when the machine is turned off?
No, the fan is not meant to run all the time, and not with the unit in standby. The fan in many DVD recorders is usually only meant to be active whenever a disc is loaded and is either recorded or played back - the fan is designed to circulate the airflow for the DVD drive and its associated digital controller circuit. If the fan is still running even after you ejected all discs/tapes, and turned the unit off at the front, then it will require a service technician's attention in a fully equipped workshop. If the fan does not run when the unit is in standby, then you have no fault; it is a normal condition.
Apr 04, 2011 | Toshiba Televison & Video
Sounds like fan is continually working, should it be doing this even when just on standby?
No it should not go in standby. They do wear out. When they do, they run longer and harder. Just replace the fan and it will go back to normal, also closing any unused programs will help
Dec 22, 2009 | Advent Netbook
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Case fan runs on standby
Hi neezels, go to page 53 in you're manual. Scroll to the bottom of the page to ( System Smart FAN Control). This is you're case fan. This is why you're system fan is running while in standby.
By enabled you're case fan will still run but adjust it's speed acording to the motherboard temp. Even though you're system may be in standby you're case fan will continue to fun to maintain temp. (Pretty smart noard)!
Mike
Apr 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Ge profile artica refer fan speed PSS29NHPBWW
hmmmm no thats peculiar it will slow down and start back each time the doors are open also fan will turn on even if fridge is turned off if a door is opened londer than 3 mins. If the fan still operates irradicly even in the liner protect mode (turn refrig off open door for 3 mins, fan turns on) then the main board is faulty not uncommon for these refrigs.
Sep 28, 2007 | Refrigerators
Model number not listed
That is a good question. My Model FTR184 Windchaser fan is not working either (has standby light on, and doesn't run, even when temperature setpoint is reduced to less than room temperature (in the PS - personal settings - mode), and more frustratingly, even in the FAN mode, where there is not supposed to be a Standby mode. That darned red Standby LED light just stays on no matter what mode I have fan in (though it does go off when I operate the Power on/off switch to turn everything off. So, I agree with Lease. Why isn't our fan model listed? And, of course, what is wrong with mine.
Sep 02, 2006 | Windchaser FTR163 SensorFan Stand...
Inner fan
inner fan is working all the time in order to cool off the electronic units, but you may wanna try checking for overheating. this can resault of: - air hole too close to the wall, or jammed by something. - working enviroment is too hot. room temperature and so. - dust and dirt accumulated on the fan, or heatsinc. you can clean it with a vacum cleaner or compressed air.
Feb 22, 2006 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
95 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
