Question about HP Officejet 5610 All-In-One InkJet Printer
Officejet 5610 I have put the colour cartridge in the slot for the black one and now it is jammed. How can I get it out?
I just had this problem and I got it out with pliers
Posted on Sep 23, 2010
  • 234 Answers
Thanks for trusting me Arthur84
Bad News that you have put the wrong cartridge in the wrong slot.
If you call HP they will replace both the Cartridge and the All-In-One as this is not possible to take out the cartidge from the wrong slot.
But if it is possible please apply little more pressure and try to take the cartridge out from the slot and try replacing it to the right slot.
If your printer is still in warranty then you can get both the cartridge and the All-In-One Replaced for free, if not you may opt for the Out Of Warranty Upgrade option Through HP Tech Support.
Good Luck Arthur.
Posted on Sep 06, 2008
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
5610 all-in-one wont print black
ink cartridge magenta will not print and the cartridge is full of colour
Nov 03, 2012 | HP Officejet 5610 All-In-One InkJet...
I put the black cartridge #56 into the tricolor in an HP 5610 Off
It just is "jammed" into place, like a round peg into a square hole.
Use a bit more strength, in order to "unjam" it.
Or, if you are not comfortable, take it to a qualified printer technician,
and let him/her remove it.
Nov 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge stuck in Printer! HP OfficeJet 5610
I Got it! I just did something similar, black ink in color slot. At first I tryed prying and yanking and wiggling all to no avail. When I actually stopped and looked at it, I could see a little lip sticking up on the back left side of the cartridge, the chamber is made for a little lip CENTERED-so used my left hand on the side of the ink to push it to the right so that the lip would slip through the slot in the chamber while I pulled with my right hand-IT WORKED!!!! Came right out! If you put the color in the right (wrong but (R)) side-try pushing from the right to the left while pulling out. The key is to LOOK and guide the lip on top of the cartridge through the little slot opening in the chamber. Good Luck!
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP officejet 5610 all in one is not printing black colour. Message flashed is align left cartridge. However, despite changing the cartridge same result.
u have to clean ur cartridge nosel u have remove cartridge from the printer then take normal hot water then put the cartridge nosel on it then take tissue papaer to clean the cartridge
Feb 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Printing colours
The color cartridge is faulty, you need to replace it.
If it is new ask a refund.
After putting a good cartridge do head cleaning.
Sep 03, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
158 people viewed this question
Ben Johnson
