Question about RCA F36650 36" TV
Intermittent No Video (6 Year Old TV)
Problem has happened now 3 times over the last 2 months and is becoming more frequent. Event: No video on remote power on:
  • TV not turned on all day till 3pm - Problem usually occurs after TV has been off for an extended period (~12 hours or more or overnight)
  • Powered TV on with remote
  • TV turned on - heard relay pull in
  • Heard de-gaussing/static that followed
  • Volume ok
  • No video
  • Tube gun heater elements not on
  • After about 2 minutes video came on
When video comes back and I put it in Service Mode I get Codes:
P1 26 Not Defined
P2 26 Not Defined
P3 24 Not Defined
I don't believe this is a transformer. In my experience the transformer is either good or bad. I am thinking more of the controlling circuit. Thank you. Jeff
  • ms0241 Dec 01, 2008
    Going on 3 weeks now - working solid.
    The Fix
    : Resoldered:
    * Both ends of LL04 (inductor between HOT and Horiz Drive Txfmr LL01). This is the inductor in the troubleshooting tips they tell you to check. It is on the output of Pin6 of LL01. No visible cracks or problem.
    * CP65 and CP76. I removed them to check capacitance then reused them.
    Also:
    * Tie Wrapped both ribbon cables from GEM4 module away from power resistor.
    * Per SN - Replaced 2uF cap with 4uF cap to reduce power on current draw.
    Only new part that helped fix the problem was the Horizontal Output Transistor (shorted).
    Genius:
  • RCA Master
  • 1,550 Answers
Check for cracked solder joints on the coil near of the horizontal output,are between there pins
Posted on Nov 04, 2008
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
Westinghouse Setup wizard
westinghouse will not work with an APPLE remote
Jun 09, 2013 | Westinghouse Televison & Video
LG 42PC3D Plasma TV Will Not Stay On
Could be a failing poser supply
Apr 22, 2017 | Televison & Video
Sharp Aquos 32 nch TV, turn TV on, come on & goes off withn 2 sec
You have an intermittent power supply issue. See if you can get a used one on the cheap.
Aug 23, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
On and off
That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
Jul 28, 2008 | Philips 55PP9352 55" Projection Television
NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
