Question about Electrolux EW1200i Front Load Washer / Dryer
Ew1200i washing machine problem
I have a washer dryer ew1200i problem is that it stops half way through cycle and has to be manually clicked to the next click, could anyone please tell me what the problem could be
My washing machine is doing the same. try adding water in manually via the dispenser drawer. see it this helps, it should then advance to the next stage. you'll have to repeat when it requires water. i'm currently fault finding myself to see what the next solution should be.
Posted on Sep 22, 2008
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Hi we have the electrolux EW1200I and it doesnt spin when washing therefore all the clothes are soaking wet. Any help???
here could be 1 of many faults it could be the drive belt has snapped but in dryer mode if it turns then probally not, always check your filter and look at the back of filter recess to make sure nothing is tangled around pump impeller
May 20, 2010 | Electrolux EW1200i Front Load Washer /...
My machine lights up but once you shut the door it
the door activation switch is stuck in a open circuit and you have to remove the door itself to obtain access to replace!! the switch
Jan 22, 2010 | Electrolux EW1200i Front Load Washer /...
Washer will stop washing and I get a reading of stuck key
Power on the washer & press 'end of cycle', wait for a couple of minutes to try the door, gently.
Feb 01, 2009 | Electrolux EW1200i Front Load Washer /...
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Not spinning after first 3 second spin on start.
You need a new PCB. THis happens often on these machines.
Nov 23, 2007 | Electrolux EW1200i Front Load Washer /...
Aqualux 1200i
did you happen to solve the problem? I am having the same exact issue with mine...washes fine, but won't do the spin cycle. it spins counter clockwise really slow at first, presumably to balance the clothes, and then starts to spin up clockwise (to do the spin cycle) but then whinnies and then stops....!
Oct 14, 2007 | Electrolux EW1200i Front Load Washer /...
Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Electrolux ew1200i
Here is the link to the manual; http://www.serviceforce.co.uk/pdfs/U04216.pdf Hope this helps :)
May 03, 2007 | Electrolux EW1200i Front Load Washer /...
Electrolux EW1200i Front Load Washer / Dryer Logo
199 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
