Question about Uniden Cordless Phone
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
No dial tone on above phone
  • 1 more comment
  • Anonymous Sep 06, 2008
    THE PHONE MIGHT TO HAVE TO BE "RE-IDENTIFIED " WITH THE MASTER BASE STATION. TRY TO RE-PLACE THE PHONE WITHOUT THE DIAL TONE ON THE MASTER, NOT THE SLAVE, CHARGING STATION FOR A SHORT TIME.
  • Anonymous Nov 01, 2008
    Both the master & the slave handset say "out of range." I have replaced both batteries, with no change. Any other ideas?
  • Anonymous Mar 17, 2014
    ge no dial tone
If you haven't already, try unplugging the master base from the wall, and then waiting a few seconds and plugging it back in.  I had the same problem and it seemed to do the trick, both phones are now back in range.  Hope this helps!
Posted on May 22, 2009
TRY TO RE-ACQUAINT THE DIAL TONE LESS PHONE TO THE MASTER CHARGING BASE STATION FOR A SHORT TIME
Posted on Sep 06, 2008
What does it mean what your phone is out of range
2 Suggested Answers
  • 50 Answers
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Posted on May 28, 2009
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
Model no. 26928ge2-a need to change from tone to pulse
Press and hold the program button until you hear a beep.
Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
Press the program button again. You will hear a confirmation tone.
The above is from the fourth column of the manual at
http://www.home-electronics.net/USER-GUIDES/26928_DOM_ES_CL_IB.pdf
Sep 09, 2011 | GE Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
One of my phone is stuck in search mode what do i do it i a vtech 6772.It is a three phone combo other two phones work fine
HI, To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
thank you,
vijay
Sep 29, 2009 | Vtech Two Line Digital Answering Machine...
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
May 28, 2009 | Uniden Cordless Phone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
557 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
