Question about JVC GR-D290 Mini DV Digital Camcorder
Trouble downloading from camcorder to PC
I have checked with the firewires...they do work. But it seems that the camcorders are starting to freeze up and not download (capture to PC). The same firewire in a newer camcorder (Sony) will work with Adobe Premiere Elements 3.0.
I have Windows XP.
    Master:
  • 763 Answers
Use ULEAD MOVIE MAKER as your uploading software and try to use USB as your connection to the camcoder and pc.
CHARCOIS
Posted on Sep 05, 2008
How can i download the contents of my mini tape onto the pc ?
you don't convert the files, you just downlod them via a firewire comnnection.
If you have a mini dv (cassette) camcorder....
Your dv camcorder needs a firewire connection (ieee 1394) in order to download video, your PC probably did not come with a firewire port, so you will have to buy one and install it, since most computers (except possibly brand new) don't come with a firewire port, your camcorder did not come with a firewire cord so you have to purchase a cord too. Your camcorder did come with a USB cord and that is used for downloading stills from your camcorder. Make sure your camera is in playback mode.
Open your editing program and choose the capture mode.
The fine print in your manual makes reference to firewire (ieee 1394) connection....
thanks.
Apr 11, 2011 | Cameras
Can't connect my JVC camcorder to my PC
You need to install the drivers BEFORE connecting pc to camcorder
Jun 22, 2008 | JVC GR-D350 Mini DV Digital Camcorder
Window 7 problem cannot detect my video cam
After connecting the Camcorder to the Computer with the Firewire/i.LINK, turn ON the Camcorder.
Keep the Camcorder in Playback mode.
Start the Moviemaker Software which is pre-installed in the Windows.
Check whether the Camcorder is recognized as the Video Device.
If the Camcorder is not recognized, then check whether it works with other Computer or not.
You may also try using a different i.LINK cable that is compatible with the Sony Camcorder.
Sony Camcorder have 4 pin DV Interface and the Computers may have either 4pin or 6-pin i.LINK/Firewire port. So make sure that you are using the correct cable.
Jul 22, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
1394 Firewire Problem - Locks on Boot-Up When the cable is plugged in
you could try to reseat the card. sometimes the cards don't fit quite right and when you plug in the cable maybe it moves it enough to get a bad connection.
does it post with just the cable pluged in pluged out?
did that help:)
Jan 29, 2008 | ASUS A7V8X Motherboard
Panasonic DS27 Camcorder IE1394 firewire out problem
http://www.panasonic.co.uk/customer-Support/download-centre.asp
See bottom two files, I think you may have a problem with your firewire port on your camcorder
Dec 06, 2007 | Video Cameras
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
Downloading Camcorder to PC
I've learned my lesson and will share it. Use firewire and try WinDV. Best of luck.
Sep 06, 2005 | Panasonic AG-185 Camcorder
JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-D290 Mini DV Digital Camcorder Logo
88 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
