Question about Kitchen Appliances - Others
Power surges im a maintenance supervisor in a apartment building built in 1964 yesterday a resident reported power failure in one section of apt. for about a half an hour.she also said the lights were dimming and then surging bright also claims to have heard a crackling sound. no breakers were tripped. when i arrived at the apt everything was workinhg fine, i never came across a situation like that before.can someone give me some tips
  • 640 Answers
I would check the panel (circuit breaker box).Remove the screws around the panel and lift off.Check the 3 phase incoming wires,they will be the largest thick wires.Check to see if the insulation has burned off the wires exposing the copper.If so the wires could be breaking down or some kind of appliance or load is drawing too much amperage.Also check from other residents if they have had a problem,if so the transformer on the pole feeding the building could be failing.
Posted on Sep 06, 2008
How long is the normal repair time on a telkom line fault?
Youre not the 1st i read having troubles with telcom. Just quit and get smbd that actually works
Feb 25, 2018 | Internet Computers & Internet
I've got a Rittling water source heat pump chassis unit in an apartment, cooling tower, with a Honeywell focuspro 6000 Tstat. The fan turns off when set to On and Cool after reaching set point. The...
you would need to make sure that the "G" wire is connected between the controller and the unit. this is the wire that will run the fan continually even when it isnt cooling. the controller sounds like it is programmed fine if it has an ON option in the fan section of the Pro6000 it is set fine it just needs the G wire run
May 02, 2014 | Heating & Cooling
Lasko ceremic heater hot cord and melting
Yes it could be the outlet or the more likely wiring to it. If your apt has a maintenance preson have that person take a look if not call an electrician.
Dec 03, 2013 | Lasko 760000 Cyclonic Ceramic Heater, 750...
PRINTER REPORTS 'INK SYSTEM FAILURE' MESSAGE 0xc19a0023. Have cleaned everything per HP recommendations, reset several times but problem remains. Do I need to replace printhead?
1.Press '*' key on the key pad, then press the '#' key and release them both.
2.Then enter '123' to enter maintenance mode.
3.then press the right arrow (beside the OK button) until System Configuration menu appears on panel.
4.Then press OK two times to clear the error condition,
5.then cancel two or three times to return to the top menu.
6. Then power off and back on, print a test page
If this does not help you then the printer need to be replaced you can call HP and talk to the Supervisor
Apr 26, 2011 | HP Photosmart C5380 All-In-One Laser...
After a 5 second power outage, the tv will not turn on.
Possible that the power while returning had a surge- this happens as the power needs to load up to stabilize . So it is always ideal to switch off power to all electronics devices when the power fails as if you are residing in the vicinity of the transformer then the surge will be high.
This will effect the power supply section which is a SMPS unit. Possible fuse or a driver would have failed.
Please check the link below for help:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 15, 2011 | RCA P52926 52" Rear Projection Television
Trying to establish approximate age of old Hotpoint Refrigerator
http://www.waptac.org/sp.asp?mc=techaids_refrigerator_energyuse
Looks like between 82-84
Jun 25, 2009 | Refrigerators
Orange Power light flashing
Most likely a power supply failure. It apears that the power supply is not putting out all necessary voltages.
Replace the power supply
Sep 02, 2008 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
Broken TV in building hit by lightning
hi
depending on the intensity of the lightning strike.Your tv may have blown components in the power supply section of the motherboard.
unfortunately its very very difficult to acertain level of damage unless its looked at by a trained tech/engineer
cheers
Jun 16, 2008 | Televison & Video
Tv wont come on
i think it's the built-in power surge/failure sensor.  Plug the TV into the wall and press RESET on the remote twice.
Jul 07, 2007 | Sanyo DS24425 24" TV
Kitchen Appliances - Others Logo
48 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
