Question about Black & Decker (050876530606)
Black and Decker Coffee Maker DE790B
My coffee pot works fine. It's the burner itself I'm having problems with. It doesn't want to stay on. When it's done brewing, the burner automatically shuts itself off. I misplaced my user manual so I'm not sure what I'm doing wrong. Any assistance would be helpful.
  • 1 more comment
  • Lizzies mom Mar 19, 2009
    Repeatedly shuts off during brewing
  • joannlibby56 May 11, 2010
    can you help me with my problem my coffee maker shuts off when the brewing cycle finishes
  • jimmy cracker Aug 01, 2013
    I want one of those. I hate burned coffee.
There is nothing wrong with your unit, This is not a problem. There is no burner at all. This is a thermal carafe unit that does not require a burner to keep the coffee hot, but rather it's the thermos like quality of the carafe that keeps the coffee hot.
Posted on Jan 03, 2009
  • 5,568 Answers
The warming plate is controlled by the same thermal switch that cycles while brewing and they are mechanically in contact; it switches at about 150 degrees C.  Most later coffee makers have a time limitation as well and if they are so designed, will turn off completely after 30 minutes to 2 hours after the brewing is finished to reduce the chance of the machine failing. If you insist on having one that doesn't behave this way, you can buy a cheap one from a 'dollar store,' they don't have that feature and will continue to cycle until turned off.  Your B&D isn't malfunctioning, that is how it was designed.
Posted on Oct 22, 2008
    New Friend:
I want one of those. The burner can ruin coffee in just 5 minutes.
Posted on Aug 01, 2013
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
The unit brews coffee OK. About 2-3 times per hour, the brewing element turns on and bubbles for a few minutes. This annoys me. Will it shorten the life of the coffee maker? It has done this since it was...
Hi. The pot is turning itself on because the thermostat is telling it to do so, because the coffee in the pot is getting cold. You might try feeling the surface under the pot is sitting on to see if it is hot. if it is not hot the keepwarm element is not working, if so get rid of it and but a heavy duty coffee maker ( Bunn ) It does not pay to repair them because the fright to and fro, plus the cost of the repair. Probably made in China. Good luck. bobbyone
Aug 13, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
After brewing coffee does not stay hot.
Unplug the coffeemaker for one full hour.
When you replug it, go to Auto-Off - change the time from "2:00" to "4:00", and then brew another pot. Immediately after the brewing is done, set the coffeemaker back to Auto-Off and see if your problem is resolved.
If not, it may have deeper problems. These coffeemakers have a 3-year warranty - call Cuisinart to see if you are still in-warranty.
-Tha Mp3 Doctor
Jan 31, 2009 | Cuisinart DCC-1200 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Braun Proaroma coffe pot wouldn't brew
I found on online operater's manual for this coffee pot and solved the problem.
Aug 21, 2008 | Braun Aromaster KF 12 Coffee Maker
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Aug 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Black & Decker (050876530606) Logo
636 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
