Follow-up on Dell Inspiron 8100 problem
I followed your instructions to restart my laptop in the safe mode. Below is the message I received:
Windows running in safe mode. To proceed to work in safe mode, click yes. If you prefer to use system restore to restore your computer to a previous state, click no.
What should I do now?
    Genius:
  • 3,422 Answers
Ok,Please go for a system restore.But remember it will restore your Pc back to a previous state when it is used to work without any problems.So that means all your data is going to be erased and be restored to that date when it used to work properly.
Posted on Sep 05, 2008
How to fix error code 2000-0142
Did you try booting your computer in Safe mode to check if you receive this error message?
1. Use F8 while restarting the computer.
2. Under Windows Advanced Boot Options select Safe mode and hit Enter.
Check if you receive this error message in Safe mode.
It seems like your drive might be corrupted. If your computer is still under warranty, I would suggest you to contact them to get a replacement. But before you contact them, let us see whether Check disk utility would make a way to boot windows succesfully or not.
If you've Windows Vista Operating System disc, then try running the check disk utility from Windows Recovery Environment.
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type the following command and press enter.
Chkdsk /r
Once your machine has finished repairing the hard drive, type EXIT and press ENTER to restart your laptop.
You can also try typing the following command if Check disk fails to fix the issue. At the same command prompt, type fixboot and press enter.
For your information: If you've a Dell Laptop, then according to Dell, the error code 2000-0142 is a Drive Self Test failed error code. Visit the link below:http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang=en#HDD
hope 2 help
http://www.bostonrecycling.net/
Jun 18, 2012 | Dell Inspiron 1525 Laptop
My Dell Inspiron 1501 laptop screen suddenly went black when I was using the laptop.It went completely dead. I have tried connection the adapter to a different power outlet, disconnected and reconnected...
Follow the below steps it would fix your issue.
Method 1: First you need to try safe mode and check if you are able to boot to the desktop.
Follow this below provided link to start your computer in safe mode.
Advanced startup options including safe mode
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
Method 2:
If you are able to boot into safe mode then in order to troubleshoot this issue further, you may unplug all the external devices except keyboard and mouse and check if you are able to boot to the desktop.
Method 3: If the above provided steps don't resolve the issue then, I would recommend you perform startup repair.
Follow these steps:
To perform a Startup Repair follow the steps below:
a. Please insert the Windows 7 DVD and reboot the computer.
b. When we are prompted to press a key to boot from the DVD, please press Enter or the space bar.
c. Choose your language settings, and then click Next.
d. Click Repair your computer.
e. Select the operating system you want to repair, and then click Next.
f. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Access the link below for more information about startup repair:Startup Repair: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Startup-Repair-frequently-asked-questions
Dec 25, 2010 | Dell Inspiron 1501 Notebook
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
My Dell Inspiron Mini 10v comes on. It asks if I want to start in safe mode or last known configuration and after I click on either, the screen goes blue and gives me an error message with the following...
Yup go to safe mode, and choose system restore... follow instructions and select a time prior to when you had a problem. finish off and your PC should be all working again. Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
Mar 05, 2010 | Dell Inspiron Mini 10v Netbook
My problem is with a Dell Inspiron 8100 running Windows XP. at power on I recieve a screen giving options for: Safe mode, Safe mode w/network safe mode w/ command prompt. no matter what I chose, I recieve...
Hi
Thank you for your query
What you are explaining is a classic windows loop
Unfortunatley the only way around it is to reformat the PC
Please do the following
1) Simply put your recovery CD provided with your laptop into your DVD/CD rom drive and then allow the laptop to restart
Then simply follow the instructions on screen
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Dell Inspiron 8100 Notebook
I have a Dell Inspiron 1501 and receive the STOP: 0x0000007E error message
That usually denotes a Hard Drive error, or the like. All is not lost though. Try this..... Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
If this doesn't work I have given you a link below to help you further if needed. http://support.microsoft.com/kb/330182
Feb 14, 2010 | Dell Inspiron 1501 Laptop
Logon screen will not accept any passwords.
hi,follow these steps :
1.turn it on
2.press F8
3.select safe mode or safe mode with networking if you need internet
4.here you can save,change ,delete accounts so on
5.when you done restart and you can log on with your settings.
Jan 09, 2010 | Dell Inspiron 8100 Notebook
Hey I have a really bad problem i have trojans and spyware that I can't get off I can't even download any thing I can use Internet Explore but when I go to a web site to download something It will not let...
Reinstall the Operating System. And first thing you download should be AVG Antivirus from www.download.com. It is a free prog and is excellent. After that you can install whatever you need or want.
Sep 17, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 8400 gets a error message of 00f0 136C
Try to open Windows on safe mode (follow the steps below).
1. Restart, and when you see Dell screen, hit F8 few times.
2. Next screen select Windows Safe Mode.
3. If you can get in Windows Safe Mode, Click Start, Run, type cmd, click ok
4. In the prompt, type chkdsk c: /r and hit enter.
It will ask you if you want to run the chkdsk next time you restart, type y and hit enter. Close the command screen and restart.
5. Let it run, it will take several minutes and it will correct all the problems in the hard drive. After it finishes, it will restart and take you to the log on screen.
Hope this work for you.
Apr 02, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
