Question about HP Photosmart R727 Digital Camera
Camera error 00000018-4489-957000
2 seconds after starting, camera turns off.
  • mik_ee0414 Oct 10, 2008
    how exactly do you fix the camera for this particular error? (00000018-4489-957-000)
You have to set it up so it is 4 seconds or what you want.It is factory pre setting to conserve the battery
Posted on Oct 07, 2008
Same here
Posted on Sep 17, 2008
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Have a sony cyber- shot and out know while usign it the zoom started moving in and out on its own. now the camera turns on but just zooms in and out and then tells you to turn it off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
May 11, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
When I start my camera, it didn't work. I see the following:"Turn the power off and on again". I restart it and I see the same thing. what can I do?
Turn on the camera.
May 10, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
When i put a tape in to watch,or record,the video camera beeps and C:3123 appears i have tried everything
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
I found many people saying that they had this error and "smacked" the camera... and then it started working. This would tell us that it is a mechanical error... so, at your own risk, if the above steps don't work, I would try smacking it a bit, maybe something mechanical is "stuck".
Mar 01, 2011 | Cameras
It put access than after it starts beeping and appears turn the power off and on again
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Dec 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Error message when turned on
Turn on the camera.
Apr 27, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
Showing turn the power off and on again.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu under Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Oct 19, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Error message
If this error message appears, turn off the camera and remove the batteries for 30 seconds. Afterwards, reinsert the batteries and turn the camera back on. Perform a manual reset of the camera.
Aug 26, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
HP Photosmart R727 Digital Camera Logo
176 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
